As someone who has luyuan cells and posted tests with a ZKE-40 I would suggest you not buy LF280K grade A or B and instead buy 304 Cells. here are my results:
https://diysolarforum.com/threads/what-is-going-on-here-just-got-zke-40.49076/#post-624032 278AH & 901 WH
so averaging 276-278 with only 1 cell around 280
Based on this I conclude unlike the Original 280N or the 304 the 280K is a poor design that does not pull capacity in AH, and barely make the WH rating.
Full Disclosure: Amy Wan says these cells are fine and now generally never even responds to my chat requests saying my equipment is not professional... I also talked with Lampard Li from EVE and he said the same thing your equipment is not professional...
Its because of this reason I have decided not to ever fool with DIY again, for me 3 strikes its out, First it was Xuba, then Basen and Now Luyuan.
I will say aside from the capacity problem the Luyuan Cells work well don't do anything funny and hold voltage underload better than the Basen or Xuba cells so good, but no My sheet that I got said these were between 285-288. The manufacturing date was January 2022.
Xuba cells were the worst me for me, followed by Basen, and Luyuan were Ok, but overpriced for what was delivered.
That being said apparently grade B 280K are just
as the Docan cells are 263 AH with less than 795 WH rating, with the Luyuan Cells at least they were all around 899-903 WH.
