Cells are not money, more does not mean better.
The most important thing in a battery is the consistency of many cells.
If a battery has 4 cells, 3 cells have 285Ah, and 1 cell has 290Ah, all other parameters are the same. Then which cell is better?
Compare cell by cell, you may think 290Ah cell is better.
But, cells don't work alone, you have to put them in series or parallel.
In the above battery, the 290Ah cell is the bad one, this cell makes the battery unbalanced.
So much wrong with your post above that o don’t have time to correct it all.
I’ll just respond to this part.
When you build a battery, it is always capacity limited by the weakest cell.
The cells with higher capacity are better cells, the capacity isn’t what makes for s quality battery, it is the composition.
In a group of cells that are all exactly 280ah, except for one 290ah, the 290ah is the best cell.
You cannot easily judge the quality of a cell when it is in a pack.
The lowest “quality” cell is the one that fails first. Putting a higher capacity cell in a pack doesn’t mean that cell will fail first, and being over capacity doesn’t effect the pack performance at all.
