sailorphil
New to this forum - but following the channel for almost 3 years, so I apologize if this post is in the wrong place.
Sent a 2 year old swollen battery back to Big Battery, recieved the repaired one today.
Very shoddy repair - loose screws, caps for covers in bottom of box, one screw in a hole with no threads, decided to open it as I suspected if the repair was this bad from the outside... , found a crushed blue wire (I assue it is the high temp sensor), the wires are crushed and exposed.
Could this have been the cause of the intial failure, and what is the best way to check if the temp cut-off still works?
I do not feel safe using this battery, any advice appreciated.
Thanks
Phil
Thanks
Phil
