eugenee
- Nov 30, 2022
- 25
I came to the Show and Tell forum too early! will move to the newbie section hehe..And photos, we need photos of your setup
This section of the forum is after all "Show and Tell".
Phew, i was worried that you actually implemented it that way.I came to the Show and Tell forum too early! will move to the newbie section hehe..
We call it tuition.View attachment 123594
This weird thing started when I purchased 3000W inverter at Adventure Kings shop with 2 * 200Ah batteries and 4 * 250W panels.
My knowledge was very limited so I had to rely on the dude at the shop telling me his mate built his setup using what I'm buying. also gave me a tip that I need to buy 2 * 40A Charge Controllers. 1kW panels!
Sweet.
that's all I need.
I think it was about this time that I started buying things without much thinking.
Then I ran to a shop nearby, bought 1 * 40A charge controller cuz I wasn't confident enough about wiring.
then I got stuck cuz other wires, and terminals were not available anywhere +1hr drive away.
Since I didn't have any diagrams so I gave up after a few meaningless shopping trips.
Then I saw this PV Box on Youtube and thought it was amazing so I waste some more money on buying 2 * PV BOX. It came with a nice panel and circuit breaker!
I started watching Will's video seriously then I realised that I don't know where I'm at with my gears and I should have planned my system from the start.
It was too late to go back anyways so I just finished ordering things on Ebay.
I wasn't planning to use 3000W continuously but at purchase time I didn't know what I was doing/thinking.
I'll keep updating once the items arrive.
$ AUD
$1450 - 2 * 200Ah LifePO4 (Adventure Kings)
$780 - 4 * 250W with MPPT (Adventure Kings / not compatible with LifePO4)
$400 - 3000W Inverter (Adventure Kings)
$149 - 40A Solar Charge Controller (KickAss)
$239 - 40A Solar Charge Controller (Altronics)
$325 - 2 * 4 strings PV BOX 15A each string (Ebay)
$140+ - wires
$20 - Battery Switch (Ebay)
$100 - Battery Shunt/Monitor (Renogy)
$50 - Fuses (Ebay)
$150 - Tools (Ebay)
$340 - Lynx Distributor (Victron)
Total (so far) $4100~$4400
Where are you in building your array? All 8 panels in parallel will be a train wreck in full slow motion with voltage below your battery voltage.
Sorry, i was asking what progress you have made.I don't think I can understand "Where are you in building your array?"
Spot-on old bean!
But this is not correct. Combining panels in series adds the volts while amps remain the same. So i think this diagramed 2S string should be 22.9V and 10A. (What are panel Voc and Isc numbers? 11.45V and 10A? seems wrong)
And given that his panels do not have MC4 connectors, he has options. Maybe remove alligator clips and combine at (already purchased?) combiner boxes. Or utilize the awesome Anderson connectors somehow (not cheap to buy the connectors but many folks love them).Best bet is to hook it up as drawn and verify what's actually coming out before connecting the SCC.
Quite a bit may depend on distances required between array, combiner boxes and the SCCs. Hopefully this is working out.
Yeah, he should be ending up with 10A x 22.3V (roughly 250W).
It's difficult to know exactly what each half-panel is from the available info.
He says it's being installed in a garden shed, but when an Aussie says "garden shed" he means something like this: -
Or maybe: -
And each array will be connected to the pair of SCC!
I incorrectly recommended the MC4 Y connectors because 98% of panels have them. Yours do not.have 10 * Anderson connectors but I'm not really sure if they could be any help
My brain started getting some wake-up shorts with all the positive solar energy.That won't work, one array / string to one SCC.
You can't connect strings with different Voc (number of series panels) in parallel.
You've done some decent diagrams, better diagram exactly what you want to do.
We are getting close to a workable solution
On the using combiner box (I love the idea I don't have to waste them haha!)You can use your combiner boxes the join 2x 250W into a 500W in parallel. Then from combiner to one SCC.
If you can make Y cable with your Anderson’s that works too. But you will want a disconnect switch inline too.
Not an incorrect recommendation at all! I have some MC4 connectors and soldering/wiring tools(on the way)! I should be able to reuse some cables and do the required job! (unless it's not recommended)I incorrectly recommended the MC4 Y connectors because 98% of panels have them. Yours do not.
What is the spec of the combiner box?Given the spec of the PV Combiner Box,
That gave me a flashback to blowing one of the 200ah LifePO4 batteries with the cheap PWM SCC because I didn't read the user manual and connected PWM controller to solar panels first...Mate, when i started out I threw 3 brand new charge controllers in the bin for overcharging my camper trailer battery before i learned that I was supposed to connect them to the battery first (not the solar panel).
I then killed 2x 50ah lifepo4 batteries with a cheap single stage pwm charger which held them at 14.6v all day, everyday for about 12 months until they died.
I then killed 2x 100ah agms in the same manner.
The last few years have gone well though. I learned about the importance buying quality mppts. Same batteries for about 3yrs and no noticeable capacity loss yet
