Old_Skewler
Hello everyone,
I have a hunting cabin upstate NY currently powered by a Kohler 12kW Propane generator. I am trying to make this cabin more of a residence, so power becomes a critical item and propane gas is getting costly. I would like to make this cabin more off-grid.
My peak load is about 2,500 Watts with 4.5 kWh/Day energy usage. I could fine tune these numbers. For instance, my chest freezer converted to fridge is using more power than anticipated, so I may need to get a different brand.
The genset is 240 split phase and wired to a distribution panel: the cabin is 120V but the generator produces 240V.
My plan is to add a string of (4) 12V Lead-Acid batteries, 50AH or 100AH. I also plan to add (4) 450W solar panels.
According to NREL PVWatts Calculator, for my location and azimuth and 900W panels, I would get the following:
- 4.20 kWh / m2 / day Solar Radiation
- 1,039 kWh Annual production
A coworker, crazy scientist electrician but very knowledgeable has offered me an old stock inverter, Alpha Solaris 3500XP. Specs attached to this post. According to him, this was state-of-art inverter back in 2006 and it features a battery rack, MPPT charger for the lead-acid, 3500W inverter and 48V input. And it also has a relay for the generator to run, I believe, when batteries go below a setpoint. I have posted another thread asking for feedback on this inverter and whether I should consider it.
As of now, I would like to get feedback on the overall plan and possibly answers to some of my lingering questions:
1. Which lead-acid battery type is the safest: gel or AGM? Safety is a concern, since I will likely keep them in the unfinished basement/garage.
2. Which lead-acid battery is recommended for this setup? I do plan to use the cabin during the NY winter and I am open to heating pads.
3. Which alternative inverter solution should I consider for this setup, assuming the Alpha Solaris is a no go?
4. How does the energy balance work if I start with 48V 50AH instead of 48V 100AH?
Thanks in advance for any feedback.
