Even though you are already paying that yourself, today?
Don’t understand - what do you mean? From what I’ve understood, all PG&E customers will be transitioned to 4-9pm peak TOU plan by 2022…
I was OK at 3 times (off-peak vs. peak rates). Now it will probably 3 x 4 = 12 times.
I’m on E6 where peak is $0.45/kWh and off-peak is $0.20/kWh (so 2.25x).
If they dropped export credit to $0.05/kWh, it would be 4x export versus off-peak import (I’m covering peak consumption using my battery & GTIL inverters),
Note that this will be a charge on production capacity, not on consumption. Not clear it is on export.
Not sure which charge you are talking about - the ‘grid benefits charge’ is a tax on potential production capacity ($/kW of array).
The export credit is going to be dramatically reduced within the successor tarrif. Not clear exactly how much and according to what rules, but the ‘Avoided Cost Calculator’ is certain to translate to much lower credit/kWh exported to the grid…
Wanna bet they will still charge same fee for any zero-export capacity?
You can install solar panels, a hybrid inverter and a battery without informing the utility. How will they know you are reducing consumption through use of solar generation (as opposed to just being extremely miserly with electricity consumption?).
The worst I’m expecting is a minimum charge per month for ANY customer connected to the grid (which I have no problem with).
"We find the name “Grid Participation Charge” sends a clear message to the customer that they are paying to use the grid. The charge will be a fixed monthly charge based on the number of kilowatts installed in a residential customer’s system."
Yes, which is why when 10 years have passed and my NEM1.0 terms are ending, I’ll be informing PG&E that I’ve decided to decommission my solar system and want to return to being a plain ol’ non-solar customer…
Even with credit for export 25% of rate for buying power, batteries don't save you money, at least not much.
I’m my case, the ‘Grid Benefits Charge’ adds up to 50% of my annual electricity bill before I added solar.
So with a battery such as an EV to store up excess AC solar energy without exporting it and then using that stored energy to offset consumption after the sun has gone down, I’ll be saving that ~$384/year (or at least down to whatever minimum monthly bill PG&E imposes on all customers).
When I considered my 3:1 price difference between peak and off-peak, I said PV panels cost $0.025/kWh amortized over 10 years, an LiFePO4 cells cost $0.05/kWh over their cycle life which is about 10 years. Balance of system costs vary, but so to useful life. If 4:1 price difference in the future you might eke out a small savings, but not worth it.
If you can put in 4x the panels, just do that and use net metering as your "battery". (assuming you do NOT also get hit with the $8/kW/month penalty. Which you do.)
If you can't add panels, then batteries are worthwhile to avoid paying $0.50/kWh.
That is the point. The $8/kWh/month ‘tax’ is a huge incentive to get storage and rely on the grid only to cover peak power demand and power during overcast spells.
Cover your average consumption with a battery and some panels, ‘use’ the grid only for backup when you need it, have as little to do with your utility as possible, and you’ll be doing as well as you can (at lowest capital costs possible).
Let's look again at what $8/kW/month means:
I say you can buy all hardware for a grid-tie system for $1/watt, e.g. $5000 for a 5kW system.
5 kW x $8/kW/month x 12 months/year x 10 years = $4800
The tax is as much as the system hardware!!
(over 10 years).
Useful life ~ 20 years, or more. Expect inverter to need replacement at 15 years give or take, system lasts 30 years)
Over 20 years, the tax is 2x what system costs. Over 30 years, tax is 3x.
That’s the point I’ve been trying to make - that monthly ‘fee’ per kW of solar panels is a showstopper. It kills the value of NEM. They state that they want to incentivize more solar customers to add storage and that’s exactly what they are going to get (without export agreements).
<--- PUC and PG&E
I just read/searched/skimmed through the PUC document.
As they say about sausages and laws ...
Don’t know what they say about sausages and laws.
What I know is that this is a clear signal to us legacy customers that we need to start preparing for a ‘grid-assist’ future…
I’ve been planning to get an EV in the next couple years anyway, and when I plug that big mobile battery into the equation (with the V2L capability that is just now starting to reach the mainsteam of the EV market), I’m actually pretty excited about what the future holds (without any role for PG&E other than selling me backup power when I need it).
