As fafrd writes, for the first four years the Grid Benefits Charge proposed by the CPUC won't be that bad for customers who still have at least four years to go in their 15 year grandfathered period. But I believe that those of us who installed their PV systems 15 or more years ago will get hit with the full charge immediately.
Yes, I believe NEM 1 customers who are already past the 15 year mark are going to get moved to the successor tarrif immediately.
Remains to be seen whether they get the same 75% discount on Grid Benefits Charge for the next 10 years as do new customers activating in year 1.
Whether you need to add a battery to get that 10-year discount or you can disconnect and then reconnect a ‘new’ system (at least including new batteries and probably also a new hybrid inverter) remains to be seen.
And I agree that installing batteries to store surplus power our PV systems generate might make more sense than giving it to our utility companies for 5 cents per kW, especially if battery costs and installation costs drop considerably. However, the proposal reads:
"The charge will be a fixed monthly charge based on the number of kilowatts installed in a residential customer’s system."
I expect PG&E to interpret the phrase "residential customer's system" to include storage, since batteries are part of the larger system. If so, the 20 kWh of storage capacity needed to capture the unused output of a 4 kWh PV array would add $160 in Grid Benefits Charges to the customer's PG&E bill each month.
You raise a good point, but I doubt your interpretation is correct.
The CPUC has taken the ‘easy’ way out and based the Grid Benefits Charge on peak output capability rather than actual energy produced or consumed.
For a string-inverter-based system, that translates to peak kW output from the string inverter, from a Microinverter-based system, that corresponds to the peak output of the set of Microinverters, and in a hybrid-inverter-based system it is highly likely to be based on the peak output power of the hybrid inverter (and have nothing to do with how big the battery is).
If I’m correct, it means you’ll have a large incentive to get by with the smallest-powered hybrid inverter you can get away with.
So for example, it will cost you half as much to have a hybrid inverter sized up only cover 100% or 150% of average load instead of 100% or 150% of peak load (surge).
This means you’ll rely on the grid to supply motor inrush currents (for example) and rarely-used very high-power loads and you will only be able to power a portion of all house loads when in off-grid backup mode.
But it’s going to cost you a pretty penny to power the whole house like normal when in off grid mode.
Using my situation as an example, average load is only 350W, so I could easily supply 90% of my annual load with a 1kW hybrid inverter (8760kWh annual maximum output).
That 1kW hybrid inverter would only cost me $8 per month (without discount), or 80% of what I’m paying now under NEM 1.0.
My electric oven consumes 3kW when the element is on and if I add a few other loads to that including inrush current when the main fridge turns on, I’d need at least a 4kW Hybrid Inverter if not a 5kW Hybrid inverter if I want to use the electric oven during an outage.
That would mean monthly Grid Access charges of $32 or 40 per month, 3-4 times higher than I’m paying now (and ~half of my annual electric bill from before I installed solar).
My current system is 3.5kW of Microinverters, so if I was to do the easy thing and connect a 3.5kW AC-coupled hybrid inverter in year 1, my non-discounted rate would be 3.5 x $8 = $28/month but after applying the first year discount, it would only be 3.5 x ($8 - $5.25) = 3.5 x 2.75 = $9.625 or ~4% less than I’m paying now…
If I was already past 15 years and facing the full undiscounted successor charge, I’d probably elect to decommission and install a ‘new’ system with a hybrid inverter and a battery.
Since I’m 5 years in and the CPUC has reduced my original remaining 15 years to only 10 additional years, the 10 year runway I’d get on being a ‘new’ solar customer under the ST and the 10 year runway I have remaining under NEM 1.0 are identical, so I’ve convinced myself I ought to track how these transition to ST rules work as they get rolled out…
It’ll really come down to what degree of ‘newness’ PG&E requires to get a ‘new’ agreement under the successor tariff.
If you can qualify for a ‘new’ agreement under the ST (with year-1 discounts) by merely replacing your current string inverter with a hybrid inverter + battery, it’s probably a no-brainer (at least if the Utilities’ battery invectives cover most all of that cost).
If they won’t allow you to reuse your existing solar array, panel prices have gotten so cheap versus 15 years ago and panels have gotten so much more powerful over the past 15 years that replacing your old array with a new array which can likely be more powerful while utilizing less than 1/3rd of the number of panels (but reusing racking system, home run wiring and junction boxes) may still be an attractive option (again, it the battery incentives largely cover the cost of the battery).
I can see a rush of past-15-year and near-15-year NEM 1.0 customers jumping on the 66% year-one discount to upgrade to a new hybrid-based system (assuming the battery incentives are attractive and the rules allow NEM 1.0 customers a pathway to being ‘new’ year-1 ST customers.
If the rules don’t allow any pathway for NEM1.0 customers reaching the 15-year mark to avoid the full non-discounted ST fees, hard to see why any of those customers impacted would be in any rush…
