I don't feel I can agree with this. I've done a lot of research myself. The vents are a safety measure so that if damage is causing gasses to build up, they are released in a controlled manner with plenty of dilution with air vs. building up pressure and causing an explosion (physical and/or fire).
The gasses result from the breakdown of the electrolyte (physical, thermal or electrical stress out of scope) and are flammable. If any venting has occurred, there is damage to the battery.
Sources:
Lithium Battery Thermal Runaway Vent Gas Analysis
November 2016
U.S. Department of Transportation, Federal Aviation Administration
Lithium-Ion Battery Hazard and Use Assessment
2011
Mikolajczak, Kahn, White, Long
Modeling Lithium Ion Battery Safety: Venting of Pouch Cells
July 2013
Santhanagopalan, Yang
National Renewable Energy Laboratory, USDOE
Yes, you are correct about lithium ion, and concerning lithium ion, I totally agree.
If you done like me research, you also would have researched the production process.
During this process gassing is normal behaviour for the first (couple of) charge cycles.
Most of it occurs during initial (70%) charge at the production process.
There is always better, and our cheap pricing does have some downside, production process is probably less neat as from "real grade A" cells.
That doesn't mean these are bad.
Not at all.
Again:
Lifepo4 is not the same as Lithium Ion !!
Yes, they both contain lithium, and the process is more or less the same.
Apple and pear both grow at a tree, and are fruit, yet, totally different.
The gassing from lifepo4 is not flammable.
The gassing from lithium ion is.
Can I agree that there is some degree of damage?
Yes, sure.
Every time you cycle there is damage, micro cracks or how you want to call it.
Excessive gassing, while normal behaviour during production, will give some degree of damage.
Like a few charge cycles do.
Nothing significant.
Please STOP comparing Lifepo4 with lithium Ion!!!
They are not the same!
Lithium ion can be dangerous.
Explosive, fire.
Lifepo4 is NOT!!
I did a quick search for you YouTube to show the difference between lithium battery types
The video tells more then 10.000 words.
If you are not convinced, luckily there are dozens of examples.
I know it is not what you like to hear.
It's more easy to blaim the seller or producer then ourselves.
The light aluminium housing batteries are not intended to be used as-is.
They are intended to be compressed to eachother, allowing the pressure inside the cell to rise.
As result, there is no gassing.
No gassing, no bloating.
For a solid or liquid to change to gas, there are several factors that play a role.
Pressure is a huge one.
Low pressure, water gasses at 70 degree high pressure, it starts at 130 degree Celsius.
That is just how nature works, nothing special for batteries.
The tons of cells with bloating that are standing free, and the tons of cells that aren't bloating that are compressed should be enough proof.
Both the same type of cells, thin aluminium housing.
Both being normally used, yet one of the 2 is bloating..
What's the difference between them?
You should take my word for it.
Do your own research.
Proof me wrong..
Bloated Lithium ion and lifepo4 cells are nasty to look at.
Lucky there are many capacity tests between them on internet.
Producers claim already since the start of lithium battery that it does not effect lifecycle or capacity.
I'm still waiting to see research that shows them wrong.
* I talk about slight bloating, like my cell.
As said, there will be minor damage and some (minimal) capacity loss.
No effect, that's not correct.
Some.
Not enough to stop using your cell with the rest of the array.
It will work just fine.
Feel free to let fear guide you.
I'm happy to receive the cells you are afraid to use!!
Even willing to pay the postage costs.
They have many years of useful life in them, and I can always use some expansion of my 736Ah
Fear with lithium Ion.
Yes.
You should be afraid.
YouTube (again ? ) is full of videos where mobile phones spontaneous combust. Or E-bike.
Lithium ion is not safe.
