Rednecktek
Solar Wizard
OK Guys, I think I've got this all figured out and drawn up as best I can in Paint (I thought I had Visio, guess not).
Notes:
The MPPT Topping Charger is for keeping the batteries topped up when I'm gone for 6 or 7 months at a time. I couldn't get the lines to connect in Paint but it will connect to the bus blocks.
The breaker will also be used as the main disconnect to power off the system when I leave. The only load on the batteries should be the MPPT for the topping panels and the 12w lights if anyone goes in there.
The motion control lights are so if someone gets there after dark, they'll be able to see what they're doing once they step into the utility room. Why? Because they're already installed and I don't want to track down 24v motion detecting lights when the converter is only $15.
6x 120Ah FLA batteries in a 2s/3p config. Each pair will have its own connection to the bus blocks. I can only physically fit 6 batteries so I'd rather have the 180Ah @24v than only 60Ah @48v. Even then I'm gonna be overhanging the shelf an inch or two.
Yes, that's actually how that 70a 24v->12v converter is supposed to be wired. Weird for me too.
Last power audit put me at about 1000w Everything-On-At-Once load, I'm hoping to add in a 120v 1100w Mini-Split later and run it with the generator assisting.
I'm already over budget as it is, gonna have to cut back on other stuff even reusing what I can from the old system, so Lithium batteries are right out.
Generator cord into the AIO AC-In, AC-Out wires to the 120v power panel inside.
Parts are already in the cart, just want to make sure I'm not missing anything before I hit the Checkout button..
Notes:
