kolek
Inventor of the Electron
- Sep 29, 2021
- 682
Connected the 2 CT on the grid line L1 and L2, oriented correctly.
Problem is not solved.
This is what's happening with grid off:
- house load is 1.42kw, supplied by battery, everything looks normal.
Then I turn on grid, and it stops making sense.
- battery usage falls from 1.52kw to 0.05kw
- the house load disappears and goes to 0
- for grid, the power LED is actually flowing TOWARD the grid, like it's feeding power back to the grid, even though that shouldn't be possible with my settings.
So apparently I have solved the world's energy problems. At the flip of a switch, I'm able to create a house that uses no power, doesn't require a battery, and can send power generated from nowhere back to the grid. Makes no sense.
Can anyone help? Totally lost on this.
