YesI don't know how to check this. The checkbox at the top is checked if that is your question.
Do you have a diagram how you have all connected and CT's position?
Me think so when you switch on grid.I also don't have a CT connected. Is that relevant?
Not sure but if its not to much trouble give it a shot because I'm out of ideas.Ok I found the box with what must be the CT. Checking the manual as to what to do with it. This isn't the source of my problem is it?
Was your Time of Use settings working before your firmware update?2 and 4 I didn't had before it came up after a firmware update
Just to be safe shut down.Ok trying the 2 CT. I see how they should be connected.
Can I connect the CT to the pins with the inverter on? Or should I shutdown before connecting the leads?
Yes it was, requested a update because the mppt's where doing weird things.Was your Time of Use settings working before your firmware update?
So it seems like the "Days of the Week" screen is not mandatory to getting it to work.Yes it was, requested a update because the mppt's where doing weird things.
Did you ever set the setting from all the screenshots I provided you a couple of weeks ago in a PM, incl TOU ?
Yes, but there are 3 issues.Did you ever set the setting from all the screenshots I provided you a couple of weeks ago in a PM, incl TOU ?
I would guess not given your question
1 don't tick solar sellYes, but there are 3 issues.
1 you are selling to grid and I am not
2 you are using comms and I am not.
3 biggest problem is about 1/3 of the setting labels in your solar assistant app don't match the labels in my menus, so it's unclear what the settings are referring to
I reviewed what you sent again, not seeing TOU settings.I provided you a couple of weeks ago in a PM, incl TOU ?
Others have already posted those settings and they're not working for me. Thanks anyway.View attachment 216380
Since you are using voltage instead on comms, you will have to convert % to voltage, which will be very iffy at best given the very very flat curves with lifepo4
It's 4:30AM in Japan, I'll test it and follow up tomorrow. Thank you!Any luck with your CT?
