Onehand
New guy here. Electronics background, first foray into REAL solar systems.
I am only going to use one inverter and 8000 watts of PV input to start with, 4000 per input on the inverter. The battery rack will have 6 batteries, I ordered 2 extra, 30.72kWh..
After purchasing, I discovered this forum and have been reading about nightmares with signature solar support issues and this inverter having all sorts of problems. Now I am familiar with Chinese stuff and know that you can get bad stuff on occasion but for the most part, the quality is "ok" and it seems many people run these 6.5 inverters/charge controller units successfully with no issues. This leads me to believe that people with issues may have made mistakes in connecting it, programming or startup/shutdown procedures.
This will only be a 120 VAC backup system, used intermittently, however I would like for it to be reliable if and when we need it.
Is there anything good to be said about sig solar and these units as of late? Should I regret my decision?
Thank You.
Complete Off-Grid Solar Kit EG4 6000XP | 12000W Output | 48V 120/240V Split Phase + 12800 Watts of Solar PV [KIT-E0009]
Explore energy independence with Off-Grid Solar Kits, EG4® 6000XP inverters. Choose components, batteries, and panels. Revolutionize your energy with EG4.
signaturesolar.com
Thank You.
