TomC4306
Solar Obsessive
HUH?series FETS
Parallel.
If you're trying to sound like a know-it-all at least try to know it all.
HUH?series FETS
Fets in series with the current flow, it's multiples of parallel FETs that dictate the amount of current they'll pass.... if you're wanting to score cheap points then crack on there.HUH?
Parallel.
Hmm. Interesting. I guess as opposed to perpendicular?Fets in series with the current flow
Great, I'm happy for you.Hmm. Interesting. I guess as opposed to perpendicular?
Cheap point? No.
I already know who you are.
That guy.
A correctly configured Batrium does just what I said.
If you have a runner it will shut down the entire bank.
There is only 1 connection to a Shunt trip from the supervisor.
I don’t know where you’re buying your cells but all of them even from the same batch and manufacture have variances.
The only way you can “lower” the charge rate is to be able to talk to the inverter or CC.
Batrium doesn’t talk to Every AIO or CC.
@sunshine_eggo care to weigh in here.
....... and 1% or less use Batrium or REC; therefore, the default advise is to NEVER rely on the BMS for routine charge termination and treat it PURELY as a safety device.
The concept doesn't even apply to AiO/rack batteries, Batrium or REC as those BMS are actually in control of the hardware.
So here's the thing, it sounds like you are saying that using a communicating BMS to control the charger/inverter is your preference. (This is a fine strategy)This is just your opinion, I believe the opposite to be true, but I suppose it'll depend if you trust your BMS.
I'm not disagreeing, my opinion is that many folks aren't aware of what a quality BMS can provide in terms of control, data and stability, I disagree with the "default advice" but I'm long enough in the tooth to recognise that folks seem to enjoy doing what the off grid garage chap seems to do so I'm not intending pointing out the futility of playing lucky dip with random components.
You've either deliberately, or accidently misunderstood my opinion, I'm certainly not recommending a "BMS" that feature FETs passing the full battery current.So here's the thing, it sounds like you are saying that using a communicating BMS to control the charger/inverter is your preference. (This is a fine strategy)
But, as already stated most BMS's don't do that, so everyone is hearing you recommend using the FET based BMS to control charge/discharge by opening the FETs to stop current flow. (This is a bad strategy)
I hope now you can see why you're getting the push back on your opinion.
I'm pretty sure I understand.You've either deliberately, or accidently misunderstood my opinion, I'm certainly not recommending a "BMS" that feature FETs passing the full battery current.
If so, I agree and you are correct. (Assuming a quality BMS)using a communicating BMS to control the charger/inverter is your preference. (This is a fine strategy)
Nope, not a Batrium/Elitist at all, we've used a lot of quality equipment over the years, SMA, Schneider could equally have been added to a list of preferred manufacturers that are well proven.Few are willing to spend more on the BMS than they are on the battery. Most pursuing DIY are cost driven.
Commercial batteries are sold with FET based BMSs. Would you encourage everyone who buys one to charge to 16V because the BMS will protect the cells at ~3.65, or would you encourage users to program their chargers in accordance with the manufacturer's specifications?
Answers are influenced by the audience asking the questions.
You're a Batrium/Victron Elitist... as am I. I think the difference is that I can read the room. You either can't or aren't willing to accept that there is more than one solution besides the one you have chosen.
I'll acknowledge that the majority of folks here seem to prefer components, often called battery managements systems, that have an ability to pass current to/from a battery, and stop/start that flow if it detects a cell issue.
I believe they have been somewhat blinded, by the generally poor reliability, features and compatability of these cheap devices, to the advantages of a quality BMS, that has full control of the entire ESS, which is what the likes of a RECC or Batrium will do when combined with a Venus device, it just works.
These days people "hear" whatever they want to "hear", what was actually said doesn't seem to matter.The rest of my post was just pointing out that is not what people are hearing.
As i've previously stated, in the early days the miniscule husband, wife and a couple of mates company that was Batrium was selling products designed for folks who know what they were doing, we didn't really need their help, but their general response, or lack of it, when we pointed out documentation and firmware errors, such as their Eltek implementation wasn't ideal, but given they were drowning in trying to support folks who very obviously expecting to string a few cells together, plug in the cheapest AIO and bingo instant ESS we didn't really mind as the instant response we got from RECC when asking for custom compatibility was perfect, which is why they got lots of business, but like an old car I'm quite happy with the Batrium systems still running...... that you ignore relevant questions and only engage in using top tier hardware, spend far more than the vast majority, and have no reasonable perspective on helping those asking the questions. I'll re-label you as a top-tier elitist.
Read the rooroom
In your opinion ....You epitomize this behavior.
