I’m curious where you read this. I google questions like this and often times Quora or a similar site pops up with answers. These sites are open sites which anyone can answer a question and can be wrong.
I don’t see how this could be true, and if it is, the panels are cheaper to replace than building a system to make they are never idle.
The one exception to this would be a flexible panel. Those have a limited life of 1 to 5 years and keeping them in a closet would let them work forever, but a glass panel is in excess of 20 years with a loss of 1% a year.
This question has come up a number of times.
"Does a PV solar panel actually get hotter if you are not using the electrical output?"
My thinking as an electrical engineer says that it should not get any hotter. I think of the PV Solar panel as a battery, but sunlight replaces the electrolyte. If it is not being loaded, the voltage does rise a bit, but I can't see it getting hotter than when it is loaded to hold the voltage down. In my mind, the internal resistance combined with the current flow would cause more heat when there is a load on the panel. The counter point is the conservation of energy view. The electricity going out is taking energy from the system, and therefore will reduce the expelled heat. I don't buy it. I think of it more like a battery. A higher charged battery has a higher voltage, and lower state battey has a lower voltage, but without a load on them, neither one makes heat when it is sitting.
Who on this forum has a decent thermal camera and a pair (or 3) matching PV solar panels? I propose a simple test. Leave one panel open circuit, connect one panel into a dead short, and have the third panel running an MPPT into a battery. Have them all in equal sun and check it with a thermal camera. Is anyone equipped and up to do this test? To be totally fair, maybe repeat it a few times, switching which panels are open, connected to MPPT, or shorted.
We should also take a pole on what people think will be the hottest and coldest panels. Here is my educated total guess. Open circuit panel will be the coldest, shorted would be hottest, and MPPT in the middle. My assumption is that the solar thermal heating will be the same, and the current flow will cause a little more temp rise. The shorted panel will be the highest current, so hottest panel.
