G'day jaxone.Do you have a contact e-mail address for them ? Interested also
I had the same problem. Its partly solved by: Reverse the ventilators so they blow upwards and if you feel for it make the air flow more easily .Hey does anyone know where to get firmware updates for EA Sun inverter
I Solar SMV III 5 kW
92932006104351
Fan runs fast continually unless turned off and reset.
EA Sun support not very helpful.
The main "issue" is that the ventilators run continuously even when not needed. The inverter temperature is stable somewhere around 30 degrees celsius. If ventilators run constantly the power consumption of the inverter itself is high. Ventilators should only run in case they are needed.
I have tried to send mail to tech department but my mail gets rejected every time by the server and also using their website form does not work.
G'day. Did you eventually update firmware for your Easun inverter via link posted?G'day jaxone.
technical@easunpower.com but I really wouldn't bother. I had the impression I was conversing with a bot.
What issue do you have with your inverter?
I found an older thread on different forum about firmware updates. Someone had posted updates but they had been removed by the time saw conversation.
There was a suggestion that a Taiwanese company that assembles EA Sun inverters were helpful but don't know name of company.
