Not sure why the PDF is so low resolution. Please check.Here is the guide on how to update your Inverter Using the app
The pictures in the PDF are of low quality, not the PDF itselfNot sure why the PDF is so low resolution. Please check.
I can Look at your records If you want to pm me your stationSo I just started getting a trip by gfci high alarm. Anyone seen this yet literally nothing has changed just started this afternoon.
Yes so far a true zero!So that will give true zero export.
Edit: Ignore meHello all,
I recently purchased 2x EG4-18KPV-12LV inverters.
I realized, after the fact, that my grid power is three-phase to the panel inside my home.
I spoke to Signature Solar, and a tech told me that EG4 is working on a firmware update to get these inverters working with three-phase.
Has anyone heard anything similar or have additional information?
I'm torn whether to return these (which have yet to be delivered) and buy 3x inverters that work in three-phase configuration, or keep them and hope for a firmware update later, because I really like the specs on the 18KPV inverters.
Thanks!
So it has no access to grid AC? It's running as a battery/solar inverter only, until you toggle the button to reconnect the relay? If you wanted to charge it from the grid, with that button selected, you would have to use another charger plugged in somewhere else to a grid connection?Yes so far a true zero!
The only setting (that I've tested) that will enable grid relay is charge settings.
Charge settings can/will override the off grid setting. You won't need a second charger.So it has no access to grid AC? It's running as a battery/solar inverter only, until you toggle the button to reconnect the relay? If you wanted to charge it from the grid, with that button selected, you would have to use another charger plugged in somewhere else to a grid connection?
God how I wish this existed when I installed mine.It's basically a do not use the grid under any circumstances whatsoever unless the battery shit hits the fan. Then it will use the grid to run the loads until it can start charging the batteries again from solar. It will also charge the batteries from grid if you have that setup in your timers.
It's to bad SS didn't have select forum beta testers for new products before releasing to the public on a mass scale and needing multiple firmware revisions to keep everyone happy.God how I wish this existed when I installed mine.
It will activate the grid relay, if ON GRID CUT OFF is reach and when you set the inverter to charge from the grid.So it has no access to grid AC? It's running as a battery/solar inverter only, until you toggle the button to reconnect the relay? If you wanted to charge it from the grid, with that button selected, you would have to use another charger plugged in somewhere else to a grid connection?
