Zwy
Solar Wizard
Talk to @RV10flyer Here is one of his latest posts. https://diysolarforum.com/threads/eg4-inverters-couldnt-make-the-grade.68356/post-873760
Appreciate that. I enjoy testing things, especially inverters. I would love to test the 18kPV, Sol-Ark, Schneider, etc but they all have the same problem...they're expensive (maybe I have the problem of no money...). No one wants to send me any to play with ?.i haven’t even looked into solark how do they compare reliability wise/issue wise and importantly can they do proper AC coupling along with frequency shifting to curtail the solar panels output during grid outage when I want to create my tiny isolated black start island ?.
edited to say: @Adam De Lay can you do a video on the sol ark honestly I prefer your videos over other people you do an actual honest videos and go into details others might not
that is the boat I’m in right now money problem. I’m almost tempted to chance getting a Chinese brand inverter over these EG4 products at this point, they cost half of EG4 or sol ark quick googling shows sol ark 8K around same price as 18Kpv.Appreciate that. I enjoy testing things, especially inverters. I would love to test the 18kPV, Sol-Ark, Schneider, etc but they all have the same problem...they're expensive (maybe I have the problem of no money...). No one wants to send me any to play with ?.
This is more comparable to the 18Kpv, it has 12K continous output. https://watts247.com/product/sol-ark-sa-12k-pre-wired-hybrid-solar-inverter-system/This is
I don't know if it's the same thing in your case, but I saw the exact same issue (flickering and 120V/110V) w/ MPP 6548s.Just tried is no change in voltage and also lights are still flickering. I turn one of them off the other stayed at 111v. What's weird is for now 2P2 is at 111 and 2P1 is at 119-120 but randomly they will swap low voltage output without any changes and it only happens when it’s battery fed. When they are in bypass mode no problems with voltage of flickering lights. Makes me really wonder if the transformer is the issue it’s not properly insulated.
You sir are a TRUE genius!!!! that was it! I unhooked the paralleling cable and no more voltage fluctuations and the led lights arnt blinking either!! Oh man this saved me a lot of headaches and having to spend another 5k on another inverter!!!I don't know if it's the same thing in your case, but I saw the exact same issue (flickering and 120V/110V) w/ MPP 6548s.
Here's what I found: the dummy that hooked it up (me) didn't catch the distinction between split phase and parallel. For two units in split phase, the red and black pair of paralleling wires are NOT connected. ONLY the multi-pin communication cables should be connected. The parallel wires are to be used between units on the SAME phase.
You had the current sharing cable connected while running two 6500ex in splitphase?You sir are a TRUE genius!!!! that was it! I unhooked the paralleling cable and no more voltage fluctuations and the led lights arnt blinking either!! Oh man this saved me a lot of headaches and having to spend another 5k on another inverter!!!
Yup I am a huge dummy!! I just saw the photo on the manual and connected it without thinking I’m running single phase 240 and NOT single phase 120 sharing current mode.You had the parallel cable connected while running splitphase?
The black and red twisted pair din rail green plug cable the com gray serial are still connected. I will do a through test once sun goes down to see if truly the LED have Indeed stopped flickering. Only cables I have connect are two serial gray com cables and one Ethernet to Battery and one Ethernet - USB to 2P1 hanging in clear waiting for solar assistant to show up so I can connect it without having to take screws off of the PDP.See edit above.
Current Sharing or Parallel cables?
Nope, just a voice of experience from making mistakes!You sir are a TRUE genius!!!! that was it! I unhooked the paralleling cable and no more voltage fluctuations and the led lights arnt blinking either!! Oh man this saved me a lot of headaches and having to spend another 5k on another inverter!!!
I guess I skimmed passed that warning ?. It would have damaged it had it pushed lots of load through the inverters luckily it was minimal light and fan load I think that’s how I got lucky. It would had created circulating current between the inverters and probably fried the component.Yeah it's not confusing at all is it? Parallel cables used for communication between inverters and current sharing cables are only used between parallel connections...
Grey (parallel) cables are always used when you have more than 1 inverter. Red/black (current sharing) are only used when paralleling inverters to increase 120v single phase capacity.
@Sadow you're lucky. There's a warning in the manual that connecting the current sharing cables can actually damage the inverter when they're connected and shouldn't be.
Yup I definitely failed to read that warning. I will chalk it up to 9 lives of cat on these inverter that just got used up.
Does make you wonder...Wow that is great news if indeed that has cured your voltage fluctuations. I wonder how many other people are suffering with this?
Ok question. What did you change with your setup in this post? https://diysolarforum.com/threads/eg4-6500ex-48-expansive-lesson-learned.69104/post-873583I guess I skimmed passed that warning ?. It would have damaged it had it pushed lots of load through the inverters luckily it was minimal light and fan load I think that’s how I got lucky. It would had created circulating current between the inverters and probably fried the component.
Had me wondering for a second, but neither of us used the current sharing cables in our setup.Does make you wonder...
Right. Now I wish I would have asked for pictures earlier. Might have saved us all some back and forth...Had me wondering for a second, but neither of us used the current sharing cables in our setup.
Indeed, I can defiantly can say I was one of the dummies to not have read the manual thoroughly and just skimmed it.Wow that is great news if indeed that has cured your voltage fluctuations. I wonder how many other people are suffering with this?
hahah! probably wouldn’t have been a bad idea. Thank you everyone, I’m sorry to have wasted everyone’s time over my oversight!.Right. Now I wish I would have asked for pictures earlier. Might have saved us all some back and forth...
