I don't think you're disagreeing with me here. I like the certification process but I always question any of them due to my bad experiences. And I think your pack will last 12 years without any problems. I know you're running your pack 24/7 and I was 100% Offgrid for ten years, so I get it. Charge up to 100% then do a cycle, and try to time discharge to 0% when the sun comes up. I've had to do that many times. Not that easy but that's the only way you'll know. Need to find a way to assess capacity or else you won't have a clue.Seriously Will! You had a bad experience with Lishen cells leaking and that condemns the whole process of testing batteries for 30 days plus X-Raying , weighing them and measuring there electrical characteristics for inconsistencies? It's all useless in your opinion?
These kinds of certificates are how we are able to sustain work flow in the industry. It gives us confidence that the products we are using conform to the standards we expect. And NOBODY in the industry just follows them blindly. You would be a fool to be in the EV industry and not have several employees that randomly pull out packs in each shipment and run them on $10,000 machines to measure all of their electrical parameters etc. I would suspect they also will X-Ray some sample batteries and they are all weighed etc. The information is matched against the certificates and if it is not reasonably matched then the whole order will be further examined and most likely returned.
We certainly tested sample batches of all the products we had made. Pulling them apart and checking every component for substitutes and using microscopes to view soldering joint and traces for defects. We would even desolder large electrolytic capacitors and check them to make sure they met the specifications listed on the manufactures charts. We suspected labels could be fabricated on parts and this was actually tried on a few occasions
As for your Lishen cells leaking, that is probably not an issue that could be tested for. The battery probably pasts every test, it's just that the material holding the cell together is faulty or the chemical composition of the electrolyte is to corrosive. That is no different than the Capacitor Plague of the late 1990's when the market got flooded with bad Capacitors for 6 years from all the major Taiwanese manufactures.
I worked with those Capacitors and they tested normally and they worked normally but after the product was out in the public's hands for 1-2 years the Capacitors would start leaking all over the circuit boards.
It was found out almost a decade later that it was a faulty formula in the electrolyte that had been given to a Chinese Spy working at Rubycon in Japan. His job was to figure out why their capacitors were superior and when he realized it was the Electrolyte the company covertly let him get access to a formula, but it was actually a formula that they had failed testing because it had major long term issues. They knew he would take the formula back to China and Taiwan and pass it on to their competitors and that's exactly what he did. They then used the bad formula in all their capacitors for around 5 years and anyone who bought them ended up with lots of warranty returned items.
You keep saying that but is there any real world data that shows that to be true? I have seen a guy on here showing off an LFP battery bank that is 15 years old and it is still working fine.
Yes there is always a difference but that is a vague statement. The tolerance values in a matched set of cells used by a Tier one company will be very tiny as compared to a company that just randomly throws Grade B cells into a pack. You should charge up that eFlex and monitor the cells and then compare it with an EG4LL and see the difference. You will find the eFlex has a very slight deviation as it charges while the EG4LL has a huge deviation.
Yes at the end of the day the EG4LL balances out the cells but you have to wonder about the longevity of those cells that are always going high.
Yes one cell will always reach there first. What I don't expect is for three to get to 3.75V when the others are at 3.35V. I also don't expect it to be the same cells doing it all the time. That tells me that those cells are significantly different than the other ones in the pack.
I don't remember mentioning a firmware difference or any complaints about the BMS. I will have to look back through the posts.
The eFlex battery does not have that issue unless you want to nit pick. As I said it's all about matching and the tolerances that are accepted.
All the cells will have slightly different ESR and capacity but if they are all producing good numbers and then batched together properly it will be very small differences.
Agree but I would add that the warranty is only as good as the company that stands behind it. We have already seen threads hit 900 posts with one guy trying to get warranty service on a battery that simply did not work with his Inverter. I would hate to be trying to prove my capacity has dropped by 20% when a video of switching something on and it not working has been proven to be insufficient evidence to get warranty help.
That's the big question! Lots of things work perfectly in the short term, but the long term is where the difference lies. I just finished working on my 14 Month old GE Washing Machine. Replaced a Burned out drain Pump and as soon as I put my ohm meter on it and got 9 ohms my heart sunk because the new pump measured 40 ohms.
Sure enough the motor control board is also dead. Why is it we can't make appliances that last anymore?
My old washing Machine lasted for 15 years with only minor issues.
Your swimming in batteries so I get your line of thinking, but for someone like me that wants a pack of batteries to last 10-12 years I am not going to turn a blind eye to so many leading people in the industry saying that cells in battery packs are not all the same. If it's anything like I suspect it is, I doubt that even one production run of packs is the same as another. I suspect it's all dependent on what batteries they can get for the price point they are trying to buy them at.
That's not as easy as you might think because these batteries are running the power in my house 24/7.
And yes the warranty is as good as the company. These companies are accumulating capital quick and have good sales, they should be around for a while. But who knows. Just takes a few bad decisions to kill a company so who knows.
And I don't think of any of these batteries as special. Or "tier one" as you stated. They are all the same cells from a few suppliers, and I open them every single day. Just opened a battery this morning that didn't have the top glued on haha! I don't care how fancy these batteries are, I don't trust what anyone says about them. What matters most is selling thousands of packs and see which ones survive.
And yes the more expensive packs have cells that hit 3.7-3.8V. goes away pretty quickly and I have seen it so many times that I'm not too concerned.
