The EG4 6500EX is a good unit really. It would depend on when you purchased as to whether you might see problems. The units built until a this past winter may have problems, not all do. Gavin has a video where he removed the LV6548's again and installed the latest EG4 6500EX and reported no problems.
I threw everything at the 6500EX's when I had them installed and it did perform to expectations. No issues there. It is the flickering light/voltage regulation problem and dirty sine that was a problem. SS has those 2 inverters now, I will update when I get replacements installed. For now I'm running 2 MPP LV6548's and have scoped these and they are clean power. No flickering lights and output voltage has been rock steady. My array was setup for 400VOC due to the distance from array to inverters so I'd have to run more wire if I went totally LV6548.
I would not get in any hurry to dismiss the 6500EX. As you already have these in hand, I'd get my array setup, work on the batteries and then decide if you want to test the 6500EX's or switch to a new unproven AIO inverter. By new and unproven, just like the 6500EX compared to the LV6548, the 18K PV unit may have changes compared to the Luxpower version that can create problems.
