I found the displayed voltages on the Electrodacus were spot on in agreement with my icharger, so points to very good calibration on the SBMS40. Not sure how it does it, but it’s accurate!Also voltages between the unit (at the cell level) match the DATAQ. Match within a few
Mv. That's a BIG deal to me.
Ok that’s a shame. I can’t be the only person who would want the screen to switch off - hope Dacian adds this option in future s/w updates.There is no backlight off. Page 33 of the SBMS40 manual.
What version of iOS @Cal? Does your interface rely on opening the html file from local storage on the ipad?Strange that your iPad is not able to display BMS data. I'm working on a similar project and am able to get data on my iPad. I'm using an ESP32, coding in C and html.
I'm still in the "dark ages" with a lot of these terms. I thought my iPad gets updated all the time and as a result iOS would be at the latest version. Just checking, my software version is 12.4.9. This is less than iOS 13.0 which you say is the break point for no web operation.What version of iOS @Cal? Does your interface rely on opening the html file from local storage on the ipad?
If you’re hitting an IP address in your web browser, then your ESP32 device is acting as a web server, providing the html page to your iPad as a normal website would load, so I would expect this will still work on higher iOS versions. As I understand it (and I don’t understand it well!), it’s the specific way Dacian implements access to the SBMS40 (and SBMS0) in AP mode which means the device (phone / tablet / PC) must use a locally saved HTML file to make sense of the stream of info sent from the SBMS.I'm still in the "dark ages" with a lot of these terms. I thought my iPad gets updated all the time and as a result iOS would be at the latest version. Just checking, my software version is 12.4.9. This is less than iOS 13.0 which you say is the break point for no web operation.
Not sure of your second question. I just go to http: 192.168.4.1 and up comes the data.
Maybe you already realised, but you can adjust the shunt values for PV and Batt within the ADC menu, so if you establish that the SBMS is over reporting PV current by 12% (for example), just reduce the PV shunt resistance by 12%.I ran the screen light level settings last night. I agree I don't see any difference at all. OK so far the per cell / overall voltages are spot on. The balancing is working well considering only 200 ma passive balancing. I however found an issue i can not ignore. When the unit shows 30 amps charge I am seeing about 2.5 to 3.0 amps "over reporting" ( I need to calibrate to get an exact number ) But several meters agree within a few tenths of an amp. What caught my attention was after a full charge/discharge the % meter went to zero there was still 3.2+volts per cell available. ( I stopped the discharge at that point ) This morning I power reset the unit so it could calibrate its self during boot up, but it made no difference. I will run several back to back charge/discharge cycles to see if there is a "learning" aspect to this.
Yes I see the same fluctuating, That worries me less then the est. 2.5 to 3 amp over reporting at higher amps. In fact I saw the same fluctuations when it was powered by the USB port.I’ve been playing with the calibration this morning, but can’t get the PV offset adjustment to take effect. Not sure why.
I installed a current meter to measure the PV current, and with flat, overcast skies today, conditions were perfect for demonstrating the need for the PV offset adjustment which Dacian describes in the manual page 39, quoted two posts above.
I noticed that at small currents, below 175mA, my PV1 current reading on page 1 of monitor was close to zero (but always it seems the reading bounce around +/-10mA with noise), then they would suddenly jump to 0.175A as the illumination on my PV panels increased to allow that current to flow. Total luck, because on a normal day I wouldn’t be seeing such tiny currents.
As Dacian describes in the manual, there is a manufacturing tolerance on the current sense amplifiers, which can cause this behaviour and should be adjusted out within the Automation/ADC Menu. I tried various numbers for PV offset and none seemed to have any effect. Even rebooting the SBMS40 has no effect on this, as after reboot the PV offset numbers return to zero, they are not saved.
Generally the current readings on this SBMS40 seem unstable, or at least fluctuating within a small range. It’s most obvious with the PV panels disconnected when, instead of reading zero, PV current alternates between readings within 12mA or so. So random numbers between 0.000 and 0.012A. The same fluctuations appear on the other current meters (Batt and Load). Perhaps some noise at the inputs of the current sense amplifiers Dacian mentions in his manual.
Maybe this is normal, expected behaviour? Is yours the same @grizzzman, or do you see rock solid, unchanging current measurements?
