Mrdanielmh
- Apr 19, 2020
- 177
Hey its on Android and version 2.0.1006. I got it from wills website
That is a real old version. There's a newer version, here.Hey its on Android and version 2.0.1006. I got it from wills website
Not sure. I set the Nominal Capacity to the AHs of my pack. IIRC it was 100AH originally.@Sgt Raven you sir are a legend! Ive changed the low temp to 2c.
What is meant my cycle capacity? When I connected it asked me to set nominal capacity and cycle capacity
Since I didn't have a bigger load, I hooked up my 12V fridge and a USB charger for my phone/tablet.Amazing stuff, thank you Sir! Live saver. I need to really do a discharge test but I'm not really sure where to start!
I'll ask him to change itI wish Will would change his post with a link to the newer version.
The first time I had the fridge set to the highest of it's 3 setting for voltage cutoff. The fridge ended that test.Nice! Do you just leave them on until the BMS kicks in and stops load from being taken out? Then recharge again? What device are you using to measure the result
I don't remember how many times I have had to point someone to your download page, but it's been a lot.I'll ask him to change it
I found it quite inaccurate. That is understandable given the flat discharge curve of LIFEPO4. I ended up buying a current shunt battery monitor which measures the actual current going in and out of the battery, so as long as you know the capacity it is very accurate.The amperage going in or out seems to be pretty close, if not right on.
I've checked with my clamp meter when charging. Didn't think to check it under a load.
A customer (who isnt on here yet) found the best version yet, it solves the crashing parameter page among other issues.I don't remember how many times I have had to point someone to your download page, but it's been a lot.
I remember someone on here was trying to use that version and was having problems. But they still had problems downgrading to your previous version. It seemed his problem was a Android phone not sold in the US and using a modified version of Android OS, that was installed on his phone.A customer (who isnt on here yet) found the best version yet, it solves the crashing parameter page among other issues.
Version 3.1.1015, download here: https://github.com/FurTrader/OverkillSolarBMS/blob/master/Android_app_xiaoxiangBMS_3.1.1015.apk
ProbablyIf I install that version, will I lose all the statistical data in my current version?
I tested it on my Walmart tablet and it’s a definite improvement. Uninstalled the old one first.I remember someone on here was trying to use that version and was having problems. But they still had problems downgrading to your previous version. It seemed his problem was a Android phone not sold in the US and using a modified version of Android OS, that was installed on his phone.
Thanks ?Not yet. There is a 60 amp version out there but I never ordered any
