@ksmithaz1 do you have a set goal for battery storage in mind? That sounds like a good bit of panels, if I’m reading correctly and you had double the bank would you make it through the nights/weekends and be fine to top the batteries still as well?
18kw panels - 200Kwh batteries. So 11:1?What ratio of PV to battery bank size are you currently running?
200kwh of batteries is very expensive. Overpaneling is often less expensive if you have the real estate to mount it. Then again if you have true zero output days, it doesn't matter how many panels you have. If you live in an area with very little sunshine solar does not seem like a practical solution for power to me. $60,000+ will buy a lot of grid-juice.18kw panels - 200Kwh batteries. So 11:1?
If I truly drain my battery I can’t fully recharge in a day.
I have about 3 days of zero charging before have to break out Generator.
Been using right what I have been producing each day. 70-90Kw each day but as the days get shorter the less I bring in.
Since I got the 15kw inverters I can now double my array size.
That’s what I’m doing now.
Hopefully can get it done before it gets to cold.
Then I will be 36kw Panels- 200Kwh batteries 5.5:1 after.
Yea, you have to hit your extremes. Less sun = more panels. From a solar perspective Phoenix is pretty much ideal. In the winter, output goes down, but electric usage plummets even faster along side. Oddly though there are interesting thresholds with PV, because your demand curves are generally more consistent than your PV output. Thus you may find that since all your additional solar capacity now goes to your storage system it stays topped off, and isn't needed until later in the day, and stops discharging earlier. You shall see !10.3 kW panels, 25.6 kWh batteries for 2.5:1. Not enough of either one, although I haven’t bought from the utility since June 5th (but I just flipped the breaker On today.)
I just got the next 4400 watts of panels but not sure they’ll get up before winter.
The batteries were not $60k.200kwh of batteries is very expensive. Overpaneling is often less expensive if you have the real estate to mount it. Then again if you have true zero output days, it doesn't matter how many panels you have. If you live in an area with very little sunshine solar does not seem like a practical solution for power to me. $60,000+ will buy a lot of grid-juice.
Guests can also test the system to the fullest.I am amazed by her ability to load the system down and really use up power.......
Swear my wife does the same exact thing.I am amazed by her ability to load the system down and really use up power.......
It is All My Fault!I asked her , “ is it too much of a problem to do the laundry during the day when the suns out”?
She says” I forget”
saw mill and fire wood processor!I'm trying to decide what to do will all the wood.
and are you happy with this ratio?, or do you feel you need more battery or PV to be a better 'balance' if there is such a thing.I’ve got 8kWh of battery and 1.9kW of PV, so that’s what, just over 4:1.
