We'll I tried to bring it back, but a search for "big ass battery" on duckduckgo images provided results that were not safe for work ?This thread is getting way off-topic. I believe there are places on the forum better suited for these discussions.
Is that your imbert downdraft gasifier?
Panels are getting cheaper, batteries too I suppose...Back to the battery question - more and more companies are coming out with batteries. Canadian Solar just announced one. 19.9kwh, 10 yr warranty and 6,000 cycles. Sodium batteries are being made now, they might be available soon also. Hopefully they will follow solar panel pricing and get cheaper and better.
It's getting interesting, strap up for the ridePanels are getting cheaper, batteries too I suppose...
The real problem with using wood "gas" to run an ICE, is that the engine does not last that long. Carbon tends to build up in the cylinders and you end up needing an engine rebuild fairly quickly (like <10k mile). `
That's an issue between gasifier design and filtering. The FEMA design of gasifier is notoriously tarry. It doesn't get hot enough to "crack" the tars and leaves a lot of energy on the table. The imbert style is far superior. I have found that the key is high core temperatures. Insulation is necessary but the real secret is to preheat the in coming air in a heat exchanger.The real problem with using wood "gas" to run an ICE, is that the engine does not last that long. Carbon tends to build up in the cylinders and you end up needing an engine rebuild fairly quickly (like <10k mile). `
That has been my experience, large battery to power thru bad weather and PV large enough to recharge within a few days.I have a big battery bank relative to my PV. 9.2:1. 2.8kw of PV to 25.8kWh of LFP batteries.
Knowing I'll still be on around 90% SOC in the morning is nice. Three or four days of bad weather still sees me on around 50%
In normal good sunshine days back to back the battery bank will be fully recharged around lunchtime. After three or four days of bad weather it may take three days to get fully charged up again. It's actually quite nice having a couple of days of not hitting float and getting a full solar production day.
"I like em Big and around,Sir Mix-a-lot approves of big batteries!
Or, if you think about it the other way around, in 1975, for $3,000 you could get a 26 watt (yes, watt) panel. Today you can get 10,000 watts for the same price (in general, no inflation, etc., etc.)Who can imagine a 10kw array costing over $1 million? Today it costs $3,000
I guess if you don't catch enough rays on one day, there will be more rays to catch tomorrow.
You almost can now. $3k gets you about 16kWh.If it is like this, then it will be interesting.
Historical lithium battery prices.
The issue now is that battery packs like the Canadian Solar 20kw pack probably costs 10x as much still. When you can get 20kwh battery for $3,000, I'm in.
