Damn Yankee
I appreciate all replies. I think a few understood what I was saying but I think many do not get the point if the grid is down for any time more than a month, there will be no gasoline pumped, no stores will be open or will already be raided due to the anarchy that will ensue - THAT MEANS NO BATTERIES.
Mattb4, once again thanks for your input. That is exactly where I started - collecting from every downspout from our metal roof. The cons of that system led me to a mechanical pump (which won't work) to running the current well pump with Solar even if it was only when the Sun allowed. Unfortunately, that led to why not heat and why not hot water, and why not... Suddenly, it became whole house.
MurphyGuy, I discovered the IQ8 about 1/2 hour ago as well as a few other solutions. I think the secret sauce was Googling "what hybrid inverter will not destroy itself without a battery and no grid". There were several solutions (brands) offered. Thank you.
To Zwy, yes. Unfortunately, my pump is at the end of 750' of galvanized.
To those who offered run the batteries till they are dead and maybe they will offer some protection, I agree with that position. Open or dead short will be my only enemy, otherwise even dead batteries with no capacity present a load. In the case of having battery backup, I would probably not do lead-acid, rather a used electric car battery and charger for it. The price for used batteries is surprisingly reasonable, and certainly my nightly and Sunless days demand would be curtailed if the SHTF. In that case there is a high possibility that battery would outlast any other solution especially since I can circulate coolant through it. After all, heat is the biggest enemy to batteries.
Thank you all for your thoughts and ideas. They make me think.
John
John
