I have been guessing it means, for example, if I intersect the 625 foot curve, and 600 watts, the pump will output about 2.5 gal/min?
Or another example, if I input 300 watts, it can push a 490 foot column of water, above the water/air interface of the well, at 2.0 gal/min.
But trying to push 820 feet over the surface of the water, with 300 watts, intersects 0.0 gal/min. So the pump cannot push 820 feet unless it has minimum 520watts input power.
Anyway, I really just don't understand what that graph means. I do not have enough info, and there is no explanation to the graph on the Grundfos page.
I think your understanding of the graph is correct. Now, as I said, since the pump is variable speed and has a soft start, it might very well be ok, but I can't say with 100% certainty.
Ok, so looking at it in more detail, I've been playing with the curves for both my SQE2-55 and the 6SQF-3:
6 SQF-3
Renewable energy submersible pumps with built in inverter for solar, wind and AC powersource. Runs on both AC and DC voltage.
product-selection.grundfos.com
By selecting 'input:' and setting the input power to 0.4kW and something like 3gpm, it seem you can have a head of 128 meters (90 feet). So it does seem to be so that the pump can have a fixed limited power input and function.
