TurbineTester
- Apr 1, 2021
- 143
I have found that 99.9% of the time, estimated, our entire house, garage, barn, and RV plug can run on the 60A/240V Split Phase Output of two EG4 6500EX inverters. Where we run into some issues bumping up against or over the 13KW limits is with high power appliance like the HVAC, Clothes Dryer and Water heater. So my question is how can i implememt some smart load management hardware or software to help keep our loads more even. For example: while the dryer is something that we literally do need to run on demand, the water heater and HVAC cycles could be limited to times during the day or night when the dryer is not running. With an 80 gallon water heater we could even over heat the water during times where we aren't using other loads and turn down the hot water output at faucets and tubs to keep water temp at safe levels. With the HVAC we could have a controlled shutdown or smart thermostat that receives a signal that the dryer is on so don't run right now, or heat/cool primarily during the hotest/brightest/best UV output parts of the day. This would allow us to use the WH tank as an "energy well" or "load sink", or even pre-heat the house for the overnight chill. Are there smart breakers/disconnects/thermostats that could be paired with solar assistant or other monitoriing software to help more evenly distribute the load on our system? Thanks in advance all your brilliant people
