1.AC limiter always on
Run the unit cooling mode, set low air flow, set temperature 90 F degree, 8 times “Ac limiter button” within 10 seconds then hear 4 times “Di Di Di Di” sound, then AC limiter will always on. If want to cancel, do the same again.
2.Light status can not be remembered, because light is important to let customer know the unit is working or not. Already our side canceled the Power on Di Di sound.
3.If the solar is not good, for example morning time or cloudy days, the unit will try 3 times to start itself, 1st time 15 minutes after the unit off, 2nd time 45 minutes later, 3rd time 1 hour later, if both 3 times start itself failed within this 2 hours, then it will not try again, and will show LP(Low Power) on display. It is set to protect the air conditioner system from cloudy and rainy days, and will protect the compressor.
4.Normally for the solar inverter air conditioner keep the actual room temperature only 2 F degree gap from the set temperature without unit compressor shut down. If the room actual temperature reach or very close to the setting temperature then compressor speed very low and with very few consumption, just keep the temperature no rise no drop. If the unit will shut off and temperature gap will reach 2F with the set temperature, it means the room is too small for the unit. For example if the room is 20 square meter but installed a 24K, then very fast the house will cool and even the lowest speed of compressor and cooling will cool the house to be low, then compressor will shut down if the gap reach 2F degree.
5.App Schedule function this is Auxiliary Functions, for details upgrading we need to step by step checking, temperature schedule is very good point of this unit for sure, we will check if we can improve our unit to be smarter
