I can check kWhat's 4 ever in hours? How many amps does your charger output? You've got a 100 amp-hour battery, so a 5 amp charger would take 20 hours to charge.
Also I have mains coming in to it as well shouldn't that charge it when it's hooked in to the battery
And its bouncing aroundI can check k
It register 0.0002 dcNo idea what you're doing there. It's blurry. What little I can see suggests it can only measure AC current, not DC.
OK shut battery off and the charger is onJumping in here, but to charge the battery and make sure you do it safely it should be completely disconnected from anything else but the charger. You might also shut the battery off/on then let the charger sit for however many hours it takes to fully charge the battery. As another user noted a low amp charger could take many hours to fully charge a 100 amp hour battery
Shut down battery and have the harder on itNo. The battery has disconnected itself, hence the bP = battery not connected error.
I assume the following is required to charge:
Follow battery startup procedure
Attach charger and charge
Or 0.0065 ac
OK I will do thatThat makes absolutely no sense whatsoever.
I'm not at all confident the battery will charge if off. The battery should be started up per the manual and charged.
Well like I said it charges for a while then the battery starts to yell at me and the error light comes onJumping in here, but to charge the battery and make sure you do it safely it should be completely disconnected from anything else but the charger. You might also shut the battery off/on then let the charger sit for however many hours it takes to fully charge the battery. As another user noted a low amp charger could take many hours to fully charge a 100 amp hour battery
OK I thank you for your help will let you know what happens tomorrowI think you need more of a check list.
Battery disconnect, nothing connected.
Turn battery off
Plug in the charger and attach it to the battery
If these steps don’t work, then you may have some other challenges with the battery.
I will try both avenues and let you know may be a couple day but I thank you very muchNo. The battery has disconnected itself, hence the bP = battery not connected error.
OK the protection kicks in alarm comes on stop charging what does that mean for me it does come on after about 3 to 4 hours charging if that means it's charged it still has the bp on the inverter I'm ? connfused
At the moment 42.2At this moment:
- Are you currently charging.
- Are you showing errors.
- What is your battery voltage with the meter?
At the moment 42.2
You should add question marks to one and two, for clarity.Really? 3 questions - numbered for convenience. One answer. Why do I bother?
