To be fair, the BMS handled 80A no problem for 1 hour continuous, but I need a BMS that can handle 80A indefinitely (at least 20 hours straight).I would be very disappointed if these Heltic BMSs with active balance couldn't handle 80A discharge.
I know Heltec had a bunch of really cheap non smart BMSs on their website. I don't know which one you have.
Chargery seems to be good for high amps but I hear plenty of complaining about them too.
Also, it appears that particular unit may have had a manufacturing defect (P- bus bar only soldered at very ends, largely unsoldered to landing pad on board.
I had the best of their non-smart 8S BMSes (300A discharge 100A charge).
What I am attempting to clarify with their engineers is what current limit can be accommodated under continuous discharge relying on passive-cooling only at 25C ambient.
Whether they tell me that particular BMS was defective or not, if the answer comes back that better cooling is needed to discharge 80A continuous, I’ll probably switch to a separate-switch BMS like the Daly.
For sure, a smart BMS like the model you have should give you plenty of warning that it is overheating before any damage is done.
But the thing I learned that you may want to consider is that it is worth stress-testing your BMS before you get everything installed.
So if iou think your BMS should handle 80A continuous I’m whatever highest temps you expect it to operate in, I’d highly suggest you stress test it at that level first...
I’d be interested in any complaints you can share regarding Chargery...
