GXMnow
Solar Wizard
- Jul 17, 2020
- 2,710
For my iPhone, I just went to the App Store and searched "JK BMS" and got it from there. It comes up "Ji Kong" on the boot page.
I purchased the BMS through "Flower Dog Store" on Ali Express. I know, go ahead and laugh, they had the best price and free shipping.
I just opened my "About" page.
Vendor ID: JK-B2A24S20P
Hardware Ver: 3.0
Software Ver: 4.1.4
Manuf. Date: 200619 I assume that is June 20, 2019
Version: 2.8.4
I powered it up 18 times and it has now been on for 145 days straight since I wired up my battery bank.
My balance threshold will also go down to 0.003 volts, I have it at 0.008 right now. The quoted accuracy is 0.005 volts, but I think that is absolute drift. Mine was off a bit more than 5 mv when I got it. But it seems to as all of the cells read about the same amount high. So from cell to cell it is likely more accurate than the absolute reading. After I did a calibrate, each cell reads within 2 mv of what my Fluke reads. To Calibrate, just measure the actual voltage right at the BMS at a very low load current, and then enter that value. It then calculates the correction for each cell so the total of all cells equals what you enter. I just randomly measure 4 cells for a quick check. Hmmm. All four cells measured a bit higher than the BMS was reporting. I had calibrated it when it was about 95 F out, and today it is just 50 F in my garage. So the temp compensation may not be the best. The total pack voltage was still within 0.13 volts, so it is certainly not a gross error. And the Schneider is reporting the voltage as even a little higher. It just finished charging an shows 57.0 volts, but I am measuring 56.6 volts. That error is 0.028 volts per cell in my 14S setup. I decided to calibrate the BMS to the actual terminal voltage measured with my Fluke at 56.60 volts. And now the 4 cells I measured are reporting within 0.002 of the reading on my Fluke. I feel the BMS is the protection and it needs to be accurate to what the cells measure. I can fudge the numbers in the Schneider to get the cells to the desired voltage. Having the battery actually lower than the inverter thins is fine, as long as I set the shut off voltage a bit higher to compensate.
Hardware Ver: 3.0
Software Ver: 4.1.4
Version: 2.8.4
