my version is 2.9.0
Might want to try a different version. This is mine:
my version is 2.9.0
it shows a -2.A in Balance current
no.. it's Li-ionLooks normal to me (assuming it's not LiFePO4). Balancing is active, and you have a 0.05V delta.
sorry, on the delta you asked. i gave what i had the balance trigger set to.. that is.. 0.003v
I saw this, but i'm not sure on setting that exactly ? Do i just measure the battery with meter and enter that ?Yeah, figured that when I saw the screenshot. All good.
Also, don't forget to calibrate the voltage in the app (if not done already).
yep.Do i just measure the battery with meter and enter that ?
the 1st one was easy. but the 2nd and 3rd one didn't want to start, and i thought they were dead, but i found out that the 1st one. the discharge and charge should be shut off 1st.
ok,, kinda thought that..yep.
Yes, or just disconnect the parallel packs (disconnect switch), turn them on, then put them in parallel (making sure the delta between them is not too large).
it starts off +2a balancing, then jumps around and goes to -2a again.
ok, good to know.. i was a little worried that maybe something wasn't right, the BMS, was getting slightly warm, made me a little nervous,That is how the balance works. It tracks the cell voltages. It decides which cell is the highest and pulls 2 amps from it to store in the super capacitor bank. Then it switches and discharges the super capacitor to push 2 amps into the lowest cell. It will bounce around from cell to cell to pull them all to the average cell voltage, but it only works on one cell at a time. Mine has been working great for a year now. I only had one issue, and it turned out to be a bad balance wire. The crimp was not done well. When the connection failed it showed 2 adjacent cells at zero volts and shut down the system. Once I fixed the balance lead, it was all back to normal.
Has anyone here successfully changed the BMS name that comes up in the app when you connect to the BMS? I have not tried it yet myself, but I was asked about this from another user. If you have changed it, can you list what you had to do to make it happen.
was probably me, and i have no solution yet. JKBMS email is not working right now either..Has anyone here successfully changed the BMS name that comes up in the app when you connect to the BMS? I have not tried it yet myself, but I was asked about this from another user. If you have changed it, can you list what you had to do to make it happen.
i have done this also,, you can change the name,, but the OK button does not accept...it is as if the OK button has no function.Yes, without problems. I don't know if I remember by heart, but it's in the menu, there should be a pen icon (once connected), enter the name, done.
I think this came up in this thread earlier on - I linked the version of the app I'm using.
Edit: this one in the device list. Menu is on the top left of the app:
Not yet, I had hoped for a solution 1st, plus, I just haven't had the time much the last 2 days.. I'll look into it tonight.Have you tried the version of the app I linked to?
