Calibrating current is the active balance function. You typically want to only run this at a higher state of charge.B2A24S-15P
I don't really know what this setting does anyway or what to set it as..and the calibrating current... not sure on this setting either
Actually on the Heltec/JK-BMS with active balancing, this is not the case.Calibrating current is the active balance function. You typically want to only run this at a higher state of charge.
Well damn! I learn something new every day! Thanks for that overview, as my assumptions were obviously not correct.Actually on the Heltec/JK-BMS with active balancing, this is not the case.
The "Calibrating current" is a way to calibrate the internal current measurement to a more accurate reading. This is done by supplying a steady charge or discharge current. I did mine at about 50 amps. The higher the current, the more accurate it will be able to calibrate. Once you have a steady known current flow, you then enter the true actual current and it will then apply a calibration scale factor to make the internal current reading match the value to stated. Be careful to make sure you don't enter a bad value. If the current is already reading very close, you don't need to do this, but if it is off more than 3%, you can likely do better. This will effect the amp hours used and charged, so the more accurate you can get it, the better it will track your battery state of charge. I am not sure, but I think it may also scale the current reading for the over current protection.
The voltage calibration works about the same way, but it works best at no load. Measure the true battery voltage with a know accurate meter. Enter that value, and it will scale the internal volt meter readings to match. Keep in mind, it does not measure he full pack voltage. It just measures each cell, and then adds them up. If the number of cells has not been set, it will read wrong, and if a balance lead is not working correctly, the reading will also be off. I figured this out when one of my balance leads failed and the pack voltage was showing almost 8 volts low. The failed balance lead showed up as two cells at zero volts.
GXMnow Told me of that trick... but use a 9v battery....It's easier to do..
I think he does this on purposeBeen dropping tidbits in the comments (you know, you've seen them). He could save himself a lot of time and frustration just doing a search here
I have MPP Solar, and it uses the Pylontech protocol. I dont know what Protocol the JK BMS uses, but I have 4 of them, so I think I need to lab this out. I already ordered the Seplos BMS, as I know they support Pylontech, so I have a backup plan, and their $1000 Mason DIY kits are just too cool to pass up.I love this BMS even tho I don’t own one yet! I’m currently using the seplos BMS which has CAN communication with the inverter. Has anyone tried the CAN protocol yet?
I get that it’s not needed but it’s very useful. I thought the same as you and I’ve been using “dumb bms’s” for years now. The benefits of having the BMS communicate with the inverter is worth it.What functions can be gained with BMS can communication?
When charging, the BMS can report an accurate state of charge. Not a bad thing to have, but is it essential?
One odd missing feature is charging sources that don't have a provision for stopping charge at low temperatures. This is another thing that you should have to stop charging LFP cells if they drop below freezing temps. The JK-BMS will open the battery at low temp, but the XW will see it as a battery failure. The XW has a battery temp sensor, but it won't stop charging due to cold, only from over temp. I hope they fix that in a software update.
When charging, if one cells starts to go too high, it can tell the charge source to reduce the current. This is a good function, but it is actually covering poor cell matching and/or balancing. Without this function, the BMS might end up disconnecting the battery, and you will have to find out why it did and fix it.
When discharging, the BMS can again report the accurate state of charge. Again, this is a good function to have, especially with LFP cells as the voltage barely changes, so true state of charge can't be determined by only a voltage reading. If you are trying to ensure you have 50% remaining, then this may be needed.
If a cells starts to discharge too low, even though the whole pack voltage is fine, the the BMS can report the problem, but in most cases it will just have to shut it down. This does not help much over a stand alone BMS shutting off due to a low cell fault. In both cases, there is a balance or matching error in the battery.
Having the BMS able to talk to the charger/charge controller/inverter is certainly not a bad thing, but is it really needed?
If you are using LFP cells, I can see where having the BMS communication could help a bit, as the state of charge is hard to determine. In my case, I am using NMC cells. Their voltage changes enough and very linear, so using voltage control is not a problem at all. If the cells are not well matched, then again BMS communication would be good, but it is just correcting for another problem. LFP cells that are not well balanced and matched is where you would really need the BMS to have more control. I did a lot of reading online, and I determined that I was not worried about not having the BMS talk to my Schneider XW-Pro. If I do ever switch to LFP cells, I may look for a BMS that can talk, or I will add the Schneider Battery Monitor to at least give good state of charge data to the system.
I was looking to pick up one of those Mason kits. They still going for 1k?I have MPP Solar, and it uses the Pylontech protocol. I dont know what Protocol the JK BMS uses, but I have 4 of them, so I think I need to lab this out. I already ordered the Seplos BMS, as I know they support Pylontech, so I have a backup plan, and their $1000 Mason DIY kits are just too cool to pass up.
I am happy Andy is now testing the JK/Heltec, so we will know if it works with Victron soon I hope.
Yup, DMI inc shows it running on his youtube channel. I bought a couple Pi4's and installed it a few months back, but I was not able to gey the MQTT portion running with the database for some reason. Its probably better by now.Did someone try this ?
GitHub - jblance/mpp-solar: Python package to communicate to MPP Solar PIP-4048MS inverters (and similar)
Python package to communicate to MPP Solar PIP-4048MS inverters (and similar) - jblance/mpp-solargithub.com
Currently has support for:
- MPP-Solar and similar inverters, e.g.
- PIP-4048MS
- IPS-4000WM
- Voltronic Axpert MKS 5KVA Off-grid Inverter-Chargers
- LV5048
- JK BMS
- JK-B2A24S (HW version 3.0)
- JK-B1A24S (HW version 3.0)
- Victron VE Direct Devices:
- tested on SmartShunt 500A
- Daly BMS
Funny that Andy on his offgridgarage youtube channel finally found this BMS also. I also have 4 of them. Its been interesting watching many folks build out their Batrium configs, electrodacus, and relay based BMS's, then adding balancers. They just seem overly complicated to me after using this BMS. It simple and just works, which is kinda nice.I am starting a thread specific to he Heltec 200A Smart BMS with 2A Active Balance. 200A max charge. 350A max discharge
I have 4 of them and I bought them from the Alibaba Heltec store here - https://www.alibaba.com/product-detail/14-24S-200A-Smart-BMS-with_62544207027.html
edit: I forgot to mention this BMS is the same as JK brand. In fact the JK site has more up to date software that can be downloaded from play store or Apple. Check here for more info - https://www.jkbms.com/
Someone asked me to do a review of this BMS. I am not really ready to do a full review because I am new to DIY batteries and it takes me a long time to test these BMSs thoroughly. I actually have only used one so far. I am just getting ready to set up a second one.
And, I just wanted to start a place specific to this BMS so I can add my thoughts as I learn new information.
Of course I also want to hear from others using this BMS
My highest discharge current so far has only been about 70A and that was for a short time. My highest charge current was about 100A.
I hope to test a sustained discharge rate of at least 100A someday. My planned system would need changes for me to test higher than that and it could be years before I come to the conclusion that I need more amps. I don't expect that day to come but as I said I am new to this so I may change my mind someday.
I am very satisfied with this BMS so far.
The software is great.
The active balance is really cool. I had heard that 2A wouldn't be enough but my findings are that 2A is extremely useful and for my purposes I doubt 5A or 10A would be any better.
2A takes a long time but it keeps cells balanced perfectly. I can use 80% of battery capacity and be confident it will stay balanced. But, a passive balancer could probably do that too.
I love how it balances the cells perfectly whenever charging stops. It does even better when ever I am floating above the balance trigger.
Sometimes it can't completely keep up when charging / discharging high amps.
Sometimes it can't keep up in the knees. But so far it can always keep up enough so I am balanced if I only use 80% capacity and stay out of the knees.
@upnorthandpersonal is the one that got me interested in these BMSs.Funny that Andy on his offgridgarage youtube channel finally found this BMS also. I also have 4 of them. Its been interesting watching many folks build out their Batrium configs, electrodacus, and relay based BMS's, then adding balancers. They just seem overly complicated to me after using this BMS. It simple and just works, which is kinda nice.
I have high hopes for Seplos also, as even the new prebuilt batteries Will has been testing seems to use the Seplos BMS.
But for now, I totally agree with you @ArthurEld, these JK/Heltec BMS's are awesome. Only one complaint, and that is the need for extra voltage to boot it.
