SteveBrown
I'm trying to add the ESS Assistant in the Victron configuration tool. It requires a Grid-Code which is not available for North America. I don't have a grid tied system. So how can I take advantage of the features of ESS Assistant if I can't install it? I have heard of some who use the Europe grid-code, but then you must select 1 of 2 options. (1) LOM B Compliant or (2) No LOM detection-Not compliant (requires a password). I am very nervous about options that I cannot back out of if I change my mind or make the wrong choice. Also, if you want to remove the grid-code, you cannot do so without a password. Any advice would be greatly appreciated.
