Kenny_
Solar Wizard
The Batteries are Charged, the Sun is Shining, quit wasting PV Energy!!!
I think you mean Param 7 right? Battery Charging Current.If menu item 6 is set at it's default of 60 amps, that is 60 amps total for 5 batteries which equals 12 amps per battery, might not be enough. At 12 amps per battery it would take a long time to charge from an event 60% SOC.
I gave up long ago on closed loop for my SGP batteries. it didn’t help at all and the master battery was basically dictating everything for the others in user mode I was able to set parameters that made all my batteries happy....or is something whacked with my settings (I know, I know, not in USER MODE)....
I just can't help getting this feeling that the Inverter and the BMS are fighting over control....
That’s awesome keep it up! Never a better time to be as independent as possibleJust got the initial billing totals for December.... appears that I saved about 50% again on my electric portion of the Xcel bill....will know more once the detailed bill is available.
Oh and Xcel sent out an email saying HIGHER NATURAL GAS PRICES will cause an increase in bills in coming months. Bastards!
I'd love to get entirely off the grid but it's not likely to happen any time soon. At least I'm doing what I can....
Are you using BMS communication?I gave up long ago on closed loop for my SGP batteries. it didn’t help at all and the master battery was basically dictating everything for the others in user mode I was able to set parameters that made all my batteries happy.
Did you disconnect the communication between batteries as well? Just connect the Power cables/buss? Do you monitor the batteries with any kind of software?I gave up long ago on closed loop for my SGP batteries. it didn’t help at all and the master battery was basically dictating everything for the others in user mode I was able to set parameters that made all my batteries happy.
I like the layout of that software, much nicer than JBD...here's the reading from my bat #2 just for giggles at this moment. Note that it is cell #7 lowest in this bat/pack.
It is cell #5 in Bat #5 FWIW (not much, I know).
I'm not going to change anything immediately (Cindy says it might void my warranty. And I say What Warranty?)...I like the layout of that software, much nicer than JBD...
I would definitely change cell OV protect to 3.65V or a bit lower and the charge temp to 0C.
I'd also change the balance threshold to 3.42V and lower the delta as much as you can.
You could also change the fully voltage to 55.6 if you wanted.
It looks like you can export settings so I'd save a copy of the original if you plan to change anything..
Well if my predictions are correct, my inverter will be switching to grid within minutes.... overall battery V is 49.8 at the moment and battery 5 is disconnected.
right thats what I've seen a couple of times now.....verifying it again.#63 alarm (BMS Under Voltage) may not clear until the battery is above menu item #35 (Battery undervoltage recovery point). Menu item #35 is initially set by the battery type you select but should be adjustable, default is 52.0 but changes to 52.8 when you set L16 for the battery type. #63 alarm is just that, an alarm but as the battery charges it should (hopefully) clear when the battery voltage is at or above menu item #35. I am just guessing here but we are all learning with you (or at your expense)
battery voltage is now at 49.0 V.
Yeah, it is connected but still not figuring it out..Need to hook up the PbmsTools (or SOKTool) and look at battery 5. You will be able to drill down and see exactly what is going on
