We are going to follow an approach like this.
* Nema Rated Materials, non flammable
* Basically mounted right on the ground
* Bottom held off by a few inches for clearances
NOT MY PICTURE, NOT MY WORK
That is a PRODUCTION solution, this that I am working on is a PROTOTYPE. A prototype never looks like the final production! If it does, then you are getting ahead of yourself. A good prototype can be built from parts off the shelf at a hardware store.
Eh hem
KISS
Keep It Simple Stupid, RIGHT?
No need for the mounting system to cost more than the panels! Grrrrr......
Something like the above is clearly over-engineered. You just do not need that much support. It wont hurt, but it is very costly and unwarranted. That is probably rated to hold more snow than the face of the panels can hold.
Fine solution there, but my panels are not going to be going 80MPH.
* Wind
* Snow
* Hail
* Earthquake
Cut that down
* Wind
* Earthquake
Get the cases grounded together really well, get that back to the inverter. Set up the ground fault.
We are not trying to build Fort Knox here. What we seek is MVP for a safe setup. YEA... in the most extreme conditions, you may lose a panel or two. That is better than pricing out 99% of the public.
Working on it man. . . working on it.
It is like they are trying to make Solar like School... if you want to have it, then you must be a Debt Slave.
Nothing wrong with that. Those are 4x4's man. That is heavy timber!
When you are building something Temporary, Portable, and Modular you MUST go LIGHT.
Adding weight to something is not always the best solution. Keeping something strong and stiff... does not require weight and claptrap.
I could probably leverage 5lbs of Carbon Fiber kite spars to build a mount that would out-perform every "Qualified" mount on the market. Just a matter of allowing flex where flex is needed. . . and being stiff where stiff is needed.
Built a lot of things that fly 190mph
I can tell you that it does not happen by adding more and more steel. You ever ride in a 737? How much steel do you think they use in that bird? How much Aluminum? How many composites?
Its an old design, but a good one. We are moving on now.
Look at that, thats great
You have to think to yourself things like
* How will this scale
* How specific to this implementation is this solution?
* What if I have to change panel shape and size?
* How can I incorporate COTS (high volume) brackets and stuff?
I have a whole set of proper brackets in transit (from Signature Solar, so far those guys are great). What you are going to see me do today is a setup for EVALUATION.
Right?
EVALUATE - .>>> BEFORE
You commit to a mounting angle. You may be WICKED SUPRISED at how little you get out of your panels. Half easy. You can easily get HALF your rated output if you dont take the time to "fiddle a bit"
Bit Fiddling - K?
Experiment - if even with just one panel... if even with just an old 100W. Get up there, try it out, check your assumptions, take measurements.
Just keep looking at how everyone else did it. Eliminate as much clap-trap as you can.
* Materials Cost
* Cost of working the material
* Build time
* Teardown time
Many seemingly clever solution are horrific at time of install. Fugging fiddle bits like nuts and bolts and washers falling all over the place. TAKE EXTRA, because your gutter is going to be full of loose hardware
LOL
Rigged so much crap in my life. I used to forward WiFi over miles distance by putting up repeaters on roofs. This is far heavier, so we have to take extra precaution. I had the wind blow a lawn chair right off my roof just a couple months ago.
* Flat Roof
* Plastic lay-back lawn chair (heavy one)
* Blew right off the roof, into the front yard
So remember that!
Wind picks up something FIERCE... so account for it, or have a system that collapses quickly. Anchoring is important, but Sandbags are not welcome up on the roof. You basically MUST fasten down.
Like on a boat... tie it down or its gone.
-methods
-methods
