Vigo
I use the same approach, hit same issues. I thought about rewiring the 240v heating element to 120v like i did to my water heater, but in the end i found it 'livable' to just run it as is, when the sun is good. Something that could be done which i considered, was building some kind of interlock on the real high-power circuits so that you couldn't simultaneously run multiple large devices. But, it's really only a good idea on 'dumb' devices that aren't sensitive to repeated power cycling, plus with the drier it wouldn't automatically restart when power came back, so i decided against it. I do have a 2000w air conditioner running off a large contactor controlled by my inverter's dry contacts so it drops out if voltage falls below a certain level, and when power comes back it will resume operation automatically. I planned to do more things 'like' that but in the end there wasn't as much need as i thought.The issue is that one might go with less inverter capability and think 'I can serialize the use of things' but in practice it's easy to forget and turn on dryer + cooktop + microwave + k-cup all at once while the whole house heat-pump decides to run and wham - you're up to 4500 + 4500 + 3000 + 1500 + 1500 = 15,000w
