SolarSamAK
May I ask what is the capacity of the heat pump dryer?
Sam
Sam
Very common here. What is rare here are gas powered clothes dryers.Didn't know there was such a thing as a heat pump dryer. Sweet!
Interesting. Here residential dryer and washing machine capacity is rated by the weight of the loads they can handle, e.g. 8kg, 10kg. I haver zero idea what the volumetric capacity of ours is, it's not listed in the specs.If your washer is 4 to 4.5 cubic feet you need a 7.8 to 9 cubic foot dryer.
My Traditional resistive dryer consumes 2.5-4 kWh depending on load size. I avg 3 kWh to dry.Total 0.29kWh
Some noted powers:
Open water valve: 4-6W
Agitator: 550-600W
Slow agitator: 380-400W
Discharge pump: 685W
Spin: 500W with 1400W peak observed
Edit... not going to bother with dryer. I don't want to know, and I don't have a means of measuring energy usage on 240VAC.
Do you like this set? Any complaints?
Seems to be doing the job OK. There's lots of brands available here with these options, they all seem pretty similar. We also have a matching pair of a Fisher & Paykel front loading washer and heat pump dryer in the cottage as well and they work well too.Do you like this set? Any complaints?
This is why I bought my mom an old school style Speed Queen set (with a gas dryer). Speed Queen offers both models.Using one of them newish washing machines that don’t have an agitator. It is horrible. I build homes from the ground up. My clothes get rather dirty. The washer cannot clean them.. an agitator is absolutely needed unless you have an office job and no kids dirty clothes.. I will share a detailed graph of its power usage.
We live in a warmish climate which enables us to hang our clothes on a clothes line. That I am very happy with. Obviously uses zero power. We learned to get stainless steel clothes pins that have lasted us for years. the wood and plastic type always broke.. from what I read the sun does a better job (than a traditional dryer) of killing bacteria on the clothes.
I saw a review of this, it's an amazing machine for sure - how many loads have you run through it?Over the weekend we just got a new GE Profile all in one. Washer and dryer in the same machine, heat pump, 4,8 Cu ft. Suppose to use 1/2 the power if a electric washer and dryer. Runs on only 120v power, no 220v power needed.
Who puts plastic in a dryer?With respect to heat pump dryers, there is recent news that they should not be vented indoors as they are a major source of microplastics into the home.
I'm assuming they mean from synthetic fibres that are in most clothes these days. Polyester, etc.Who puts plastic in a dryer?
