One of your cells has to be the worst cell. If the 101.8 Ah cycle capacity lines up with a full charge-full discharge, then that’s not so bad; your weakest cell has a capacity of about 102 Ah. That’s 97% of the advertised capacity.Unfortunately I woke up this morning to see this:
So either cells 7 and 6 are bad or are (much) lower capacity.
Since initial balance, did you set the balance start voltage at 3.4 or higher? If you balance below this, it can cause some problems but this seems to be a bit much.Unfortunately I woke up this morning to see this:
From 101.8 you'd need to substract about 28 Ah. That was before I started the discharge test.One of your cells has to be the worst cell. If the 101.8 Ah cycle capacity lines up with a full charge-full discharge, then that’s not so bad; your weakest cell has a capacity of about 102 Ah. That’s 97% of the advertised capacity.
I could theoretically do that but now I lack trust in that vendor.You could look into just purchasing 2x replacements for the low cells. I have done this a number of times.
Surely there are other vendors that sell that same cell. Don't buy from them again.I could theoretically do that but now I lack trust in that vendor.
I think that these are not EVE 105Ah cells, but rather the LF90K.I purchased another 8 105ah cells from Liitokala. This time I have a EBC-A40L tester. 2 of the batteries I've tested (using various settings) come out to 88ah. I've got my original battery disassembled and will test one of those cells next. They've been in use about 4 months.
This is the store link: https://www.aliexpress.com/store/1100552573
I won't be ordering additional cells from them again
The weight of the cell that tested at 88.95ah is 2034 grams.I think that these are not EVE 105Ah cells, but rather the LF90K.
I also have ordered supposedly 105Ah cells on Aliexpress, but they all came around 85-88Ah like yours.
The weight difference between the 105Ah and the 90Ah is so subtle, that you almost can't tell the difference.
Seems like alot of the 90Ah cells are being sold across multiple sellers on Aliexpress.
Maybe they are old EVE batches or surplus (used?) from an EV project.
The link is pointing to a store that is "over capacity", no other info. I guess they took it down.I purchased another 8 105ah cells from Liitokala. This time I have a EBC-A40L tester. 2 of the batteries I've tested (using various settings) come out to 88ah. I've got my original battery disassembled and will test one of those cells next. They've been in use about 4 months.
Oh I guess I've missed your post. Just googled "lf90k eve", came across the very same cell dimensions advertised by Liitokala and finally the picture is complete. The "105 Ah Liitokala cells" are Eve LF90K with lasered out QR codes and new QR codes etched on them, that resolve to a Chinese site, with nothing that can identify the cell. They buy all crap they can find, laser out the original codes and sell the 90 Ah cells as 105 Ah cells. They don't even bother to test them because their "warranty" consists in "send cells back to the factory in China". Has anyone tried to send a LiFePO4 cell not overseas, but in a neighboring country, in Europe? Yeah, thought so... The shipment fee rivals, equals or exceeds the value of the cell, if you write "lithium battery" on the AWB.I think that these are not EVE 105Ah cells, but rather the LF90K.
