Bluedog225
Texas
- Nov 18, 2019
- 2,921
I wonder if high conductivity glue would be a solution? I’d probably want a refund on that cell before I attempted.
Only problem is one terminal is missing its threads.
Lol. Yeah, tapped it, grub screw locktited in, it’s solid.
Why are these terminal screws so tiny? M6? They should be at least M8.
It takes the LF280N between 70-76 hours to parallel top balance with a 10amp power supply.Broke out the new power supply last night, installed all of the grub-screw terminals, hooked the cells up parallel, and put the charge on them, initially to 3.4V. They've been on for over 18 hours and have only gained about 2 tenths of a volt. LOL They started out drawing about 9A, now down to 5.
I'm doing the step method - to 3.4V and rest, then 3.5 and rest, then 3.6, call them balanced. I'm guessing the second and third steps will go quicker.
So far so good...
My guess is that these cells are designed are to be implemented in battery packs with fully welded connections/bus bars. I can’t imagine an industrial use of these cells would have any sort of threaded connection with such weak method.Why are these terminal screws so tiny? M6? They should be at least M8.
These studs or serviceable connections are an afterthought to unload cells on the DIY market
Again just my thought.
What is the largest cells Jenny or Docan can supply. i can't seem to find out. on Alibaba there site hints to 500, 450 ect but no direct info.
Why not ask Docan directly?What is the largest cells Jenny or Docan can supply. i can't seem to find out. on Alibaba there site hints to 500, 450 ect but no direct info.
280 is the largest listed on the new website :
DOCAN POWER
Brand New High Quality LiFePO4 Battery Cells SupplierDocan is TOP10 battery and battery suppliers in China. We supply TOP1 service of Lifepo4 Prismatic Cell and Battery Pack for variouse area, 12 years+ focus on high capacity, high wattage, high voltage, high dicharge current battery cells and...www.docanpower.com
I'm not clear what you are asking or saying400ah? 500ah cells?
