Taser, I received a Docan 4-pack of slightly smaller EVE 230Ah cells a couple of weeks ago, to my home (altitude 5200 ft). They arrived, as expected, at relatively low state-of-charge, barely 3.26V per cell. No "bloat" was present when mine arrived. In order to remove the bloat, you will probably need to pull them down about that far, and then re-assemble your pack - with comression already applied (before bringing them way back up to re-do your capacity test, if you desire to do that).
Although you said that they've been under compression for 3 months, you didn't describe the amount of compression which you applied. These EVE cells are large, and EVE's own testing (IIRC) was done at around 16 PSI. Less than 12 PSI doesn't do much good. So your target, as described in the long and very detailed Thread on the subject of 'compression with springs' (
here), is the surface are of the big face time that pressure factor. For the case of my smaller cells, that result is about 610 pounds. Your bigger ones need around 660 lbs.
I suspect that your pressure of 'compression' was not high enough. Can you confirm or deny that to have been the case? Either way, if you try to compress them again (preferably within a spring-loaded structure) you should probably pull them down to around 3.26 volts per cell (about 35% SOC) before re-assembling your pack.
