BarracudaBob
Harvesting free photons from clean fusion
Add a ground rod by the service entrance, Bond everything together, make sure that the shed and home are also bonded together. Short answer.Question: my power shed will have six points where rebar enters the ground in sets of 4 and also 1or2 points where a stainless flow and return enters the ground, I realize these have a higher resistance than a ground rod but they will be bonded to the earthing system essentially making them supplemental rods how far should I place my main earth rod from them?
Wrong answer: Don't bond everything together & don't bond to the main utility source.
Here is the Bible for Tower Site Grounding.pdf
Overkill for most but a good read.
