Why not just use a $2 resistor, or even some pencil lead to pre charge the caps? Am I missing something because I have read the whole thread and it seems like it could be solved for $2.
I also think signature solar needs to include documentation on how to use the precharge circuit. And a video showing it in action with this Schneider inverter as proof that it works properly.
For me personally, I don't use the pre-charge circuit. Just use a $2 resistor and fire up my system in seconds.
I was actually about to try and rig up a switch with a resistor via
@MrM1 thread but around that time, Signature began suggesting that it was bms related, so i decided to wait and see what they suggested. I was also hesitant to try this because from what i understood, the battery had this function built in already. SS said i shouldn't have to do this. Eventually, in this thread, they acknowledged that they made some changes to pre-charge timing and it was likely the culprit.
At this point, they took over two months to communicate with engineering to try and find out what needed to be done to correct the issue. After two months, they were never able to even attempt any bms setting change on my system. During that time, i went to the trouble of successfully hooking up multiple types of batteries, including lithium, to my system to prove that it wasn't something "wrong" with my system.
Since i am less than 45 minutes from their shop, i invited them over multiple times to see my system in person and witness exactly the problem i was having. I told them i would hook up both other battery types with them present to see my system functions fine with other batteries. Told them i would sign any safety liability forms needed. I offered to make lattes. They wouldn't do it for whatever reason.
Seems to me a qualified electrician or EE could have told them what was happening and how to fix it fairly quickly. Hell, just from the guys on this forum, it has been widely agreed that reducing the duration of the pre-charge from 4000ms to 1000ms would likely have fixed my issue.
I also made a video showing the problem i was experiencing.
I finally convinced them to let me try the eg4 LL batteries since there have never been any startup issues with the LL model. These have a different bms and different settings. They worked perfectly, first try.
