rs14smith
- Apr 15, 2021
- 21
Ok, let me preface by saying, I know I should be check my local code, AHJ, what have you, but I'm hoping someone can simplify what I'm reading in the NEC (250.58) which I think is telling suggesting I have to use my houses grounding rod for my add-on 100W solar system that is only being used to power a garden water pump and some LED lights for my upper deck.
My Renogy aluminum framed solar panel is attached to the side of my house (wood fencing for my upper deck), but does not power anything "inside" my house (such as AC outlets, etc.) and never will. My houses grounding rod is about 35 feet away from where my solar panel is mounted on the wooden fence connected to my upper deck.
I originally thought I needed to just drive a separate grounding rod for my solar setup since the distance from my solar panel to my house grounding rod was so far and it would not be practical to run 6AWG bare copper wire 35 feet. But since my solar panel is attached to my house/building, I'm not sure how to interpret what I'm reading in the NEC.
Hopefully all this makes sense. Any help is appreciated.
