curiouscarbon
Science Penguin
- Jun 29, 2020
- 3,024
for thermal camera and shiny metal, a piece of tape like painters/gaffer type has helped me before
Plus... The 200A claimed by the jk bms, not sure how true that is. I believe @upnorthandpersonal did some testing on them.
But was it actually able to turn OFF charge / discharge at 200A after this "pre-hearing"?I did both the MOSFET calculations and the test, and the 200A version (at least the version at the time, should be same today) can handle 200A for at least an hour in my test.
There’s a reason why I own two of those and that’s the why. I had to do this completely off grid with inverter generator power for eight batteries. If I had to do it again, I’d buy something like a 48v chargeverter (which wasn’t out when I was messing with this), get them close in series and then finish with a ZKetech power supply. Either in parallel or each invidual cell. Be aware that the power supplies in these things are kinda shitty. I replaced one and bought a couple extras just in case. Sourced from Amazon.Now the question ... should I test every single of them ? They should be at around 50% SOC (3.26V - 3.29V) right now. With the EBC-A40L I can charge & discharge with 40A ... So theoretically that would be 280 Ah x (100% charge + 50% discharge) / 40 A = 10.5 hours / cell. Times 32 cells = 336 hours = 14 days full time ! More likely it's going to be 3 weeks. Not sure I'd like to wait that long to be honest .
Cells were bought from Docanpower if that matters. They have been in long term storage for a while and no, unfortunately I didn't cycle them yet. Couldn't even move in my garage in the meantime.
So you would test them before assembling the pack? Or just put them in series and measure the capacity thst way?There’s a reason why I own two of those and that’s the why. I had to do this completely off grid with inverter generator power for eight batteries. If I had to do it again, I’d buy something like a 48v chargeverter (which wasn’t out when I was messing with this), get them close in series and then finish with a ZKetech power supply. Either in parallel or each invidual cell. Be aware that the power supplies in these things are kinda shitty. I replaced one and bought a couple extras just in case. Sourced from Amazon.
yep sounds like me last year, my last two sets of batteries came in after it was getting cold, so no time to test, I had to top balance and install without testing so that I could get the battery pack heater and box built in time for winter.So you would test them before assembling the pack? Or just put them in series and measure the capacity thst way?
I'm not sure I want to wait 3 extra weeks, I'm already so late. Winter is almost here and Nu sun then ?
I don't think I have the budget for ordering so many more right now...yep sounds like me last year, my last two sets of batteries came in after it was getting cold, so no time to test, I had to top balance and install without testing so that I could get the battery pack heater and box built in time for winter.
I fought with one pack for the entire winter while the other pack behaved for the most part. (the original two packs are champs with no issues.)
This summer I pulled the last two packs and tested them and low and behold out of 32 cells i had several that were seriously lagging in capacity compared to the others. rebuilt one pack with closely matched capacities and now have extra cells. thinking of waiting until next spring and ordering another 64 cells from whomever is the most trusted at that time.
YesBut was it actually able to turn OFF charge / discharge at 200A after this "pre-hearing"?
I think Andy from off grid garage had a mosfet end up in smoke. Cannot remember the exact circumstances though. The JK still worked afterwards though ?
And do you actually use it at 200A ??Yes
Andy went over spec in that test, and that was an early 4S version which was (still is?) underspecc'ed.
So you built 2 extra packs ??Generally, no. I use the 100A version and have 4 packs in parallel, so I'm at 20kW if I somehow max these out already...
I think you need to build another 100 for that goal. Like a 40 foot container.Yes, 4 now - maybe I make another two.
I care more about capacity than power output. I want to see if I can make a pack that can last me through e.g. December when I have 0 sunshine so I would only have to run a generator once a month in winter.
Docanpower just told me to remove the black plastic top and take picturesA common trick by unscrupulous second hand LFP cell resellers, to relieve cell bloating, is to remove the blue plastic cover from overpressure vent then at the edge of vent, punch a small needle tip puncture to release bloating gas from cell. Then put blue plastic cover back on and you cannot see the pin prick hole without careful examination with a magnifying glass.
Another way is to peel back the black plastic top and drill a small hole in the top of metal housing to relieve pressure.
I FINALLY managed to put all cells inside my battery box and ... well ... a few things went wrong (again).
I'm kinda disappointed with the result really. The cost was quite high, the quality so-so and of course, for all the extra features I wanted such as contactor, light signaling, extra signal cables for feedbacks & 5V/24V PSU etc, there is NO PLACE TO PROPERLY ROUTE the cables. And every device on the side DIN rail cannot have anything "output" in the lower hole because it's in contact with the cells / cover. An absolute nightmare.
Might as well have bought a ready-to-go battery. Learned something along the way, but I think this was NOT the result I wanted . Got the cost without the benefit really.
Now at least the cells are in and squeezed lightly. More than handtight (couldn't even turn the nut by hand, would have left 20mm of gap ! - yeah 20 mm !), but "tightened" I'd say reasonably, then backed off a few nut-turns (M10 - pitch is ... 1.75 mm ?). Sometimes you can pull out the yellow spacer and sometimes you cannot, that kinda tight. But cells are NOT too loose by any means. So they may have maybe 2-5 mm gap ACROSS 8 cells at around 50% SOC.
Actually I discovered yesterday that ***** ... one cell from the second batch that I got delivered from Docanpower had suffered an electrolyte leakage probably during transport (I only noticed it now several months later when I *could* open the packages).
I promply contacted Docanpower about it. Let's see how they react.
Thankfully I had one cell as spare and put that in instead, even though it was from the first batch, so a bit older ....
By the way, how do you evaluate the status of the pressure relief vent/seal?
Some look "clean & tidy" (just the gold dot in the middle with the 3 weak spots the blow over pressure), some have "slight" bleeding (black color) around the middle gold dot, .... They are all different .
Now you are scaring me. And here I thought they were a reliable supplier ?Peel the black cover off that cell, clean gently with rubbing alcohol see if the background of the QR code looks different than the other cell. If it does than you have been scammed by Docan.
Fuck ? ...Docan? No Docan is a big time scammer, just they had a lot of buyers who were in disbelief after the relasered QR codes started circulating in the market.
Docan Power bad experience, beware.
Hello! Having read here on this forum a lot of positive feedback about Docan Power decided to buy from them on Alibaba. Ordered 84pcs of Eve LF280K cells from Docan in January. Sales rep was Jenny Wu. Cells were sold as "brand new Grade A". I paid almost USD12K for them, USD141 per cell...diysolarforum.com
Poor Docan Experience (Resolved)
Purchased 16 eve 280k from Docan over a month ago confirming the description had them as brand new, full capacity cells. Cells arrived bloated, more than 5mm out of spec at only 3.2v. No grade B QR and had the front labels that they had been "tested" at 280ah and matching IR .19. - Reached out...diysolarforum.com
Disappointing EVE 280K Results
I wanted to share my recent (September 2022) disappointing experience buying prismatic cells to the forum. My plan was to buy a small group of prismatic cells (20 cells) and test them before committing to several larger purchases based on the results of the test. I first did a bit of research...diysolarforum.com
On the subject of DDP. My experience is that they (alibaba sellers) do not actually pay the VAT on import. Instead they attach it to a different shipment eg food and presumably avoid it this way. So it’s basically smuggling. I confirm that. They call it DDP but actually it is not. I asked Jenny...diysolarforum.com
Lot of threads.
The only time you get lucky with Docan is if they send you cells from Ezeal which is a legit company that will sometimes ship out cells for Docan in there Houston warehouse. But never buy from Docan from China.
