400bird
Solar Wizard
The voltage curve of lifepo4 is basically flat at 3.3 volts from something like 30-80%It basically lives at 26.5v (charging or discharging) has been my point the entire time. Unless I discharge it below ~20%
Normally you'll see a small change from something like 3.3 to 3.32, but it isn't anywhere near linear.
What's the amperage from this charger?Not disconnecting, as far as I can tell. When I have it on the regular battery charger, I'll leave it plugged in for 48-72 hours with no change in voltage.
What voltage is this charger set to?
Is it CC/CV? Is it a lead acid charger?
At 20 amps, it would take 10 solid hours of charging.With the SCC, you know, it changes wit cloud cover. Still, sometimes it goes up to 28A max.... Sometimes I see it charge up to 28v, but as soon as I turn the SCC off, no matter what, it settles at 26.5v shortly thereafter.
Listen, there is no regulation happening in the BMS. It's on it off!I don't think the problem is charging. The problem is some sort of goofy regulation setting in the BMS itself. I've been through allllllllll this in my head. I'm quite certain it's a 5 minute fix in some setting on the BMS.
Sure the BMS measures cell voltage and calculates SOC, but it's not able to do anything to the current but stop it. It can't to anything to voltage but open and make it stop.
