After building my crazy complex Victron ESS setup, I can appreciate the simple "It just needs to do this" approach.I’m trying not to go overboard here. A little emergency station at home for lighting, phones, and fan. Couple of panels and small MPPT.
It really depends on temperature. I was able to pull 1150 watts from this unit for over an hour during bench testing.Did you know that they've dropped the "Phoenix" designation? Maybe a trademark issue.
They are now just called Inverter VE.Direct (which sounds boring).
Inverter VE.Direct - Victron Energy
Inverters allow you to power domestic equipment - requiring 230V/120V AC - using 'leisure' or 'automotive' batteries rated at 12V, 24V or 48V DC.www.victronenergy.com
Also note that the 1.2 kVA only does 1 kW of power.
You know, for occasional use, these el-cheapo ones may be worth it.I am using this one, of the 3 I tried including a Renogy, this one is fantastic for a cheap china's finest.
You've come to the correct choice. I was using my 48/1200 to power all my house base loads including fridge freezer and two other freezers, internet etc.I want a little 12 volt, pure sine, inverter.
I’ve got one of these victron units. No complaints.
It’s about $330.
Is there any real competition at a better price? Samlex?
Or am I done?
Thanks
I have this in my RV to power all outlets when needed, what I found with this which I never intended an inverter to be used for is that it starts the 12k roof top a/c and will run upwards of 1800 watts without issue.You know, for occasional use, these el-cheapo ones may be worth it.
Just don't push them anywhere near their rating, and they probably will work fine.
So the 2200W rating really should be 1100W, if you want it to last.
Thanks for the link, I wouldn't mind having one for backup purposes.
I can second that sentiment since my 24/1200 is the main inverter for my backup power plan. I’ve run my full sized fridge, boiler and pumps, lights, fans etc with it. Certainly capable and reliable.You've come to the correct choice. I was using my 48/1200 to power all my house base loads including fridge freezer and two other freezers, internet etc.
@Bluedog225 are you looking for validation of the 12/1200, or for a cheaper alternative because you can’t spare it for this new build?
It's only currently available in 12V in the US but you can parallel the 12/1200 Multiplus. Around $480 including 50A charger.I have been happy with my 24/1200 Victron, except I cannot charge my EV at 10A. I get that it's over the 1KW rating (1.2KW), but for others running theirs for an hour at 1150W, in my case it is only for about 10 seconds at 1200W.
One nice thing about the Victron too is the low fan noise. I'm pulling 600W charging my EV capped at 5A, and the fan is barely audible.
I wish we could parallel these like inverter generators are easily paralleled today without even using any sync cable. If I were super bored and had $330 to burn, I'd see if I could figure out how to do just that with these 24/1200 inverters.
