JBertok
Network Engineer
The solution to pollution is dilution.........Also, now I am saddled with the job of responsibly disposing of the old acid...
Hi,
I have seen a lot of guys using a welder to put many amps to the battery for 5 minutes to desulphate.
The DC welder I use is around 18V at the battery. It is the amps that do most of the the work. The slightly higher voltage allows current to flow thru higher resistance. What is occurring is the plates heat up from the amps and the voltage/amps push hardened sulfation off the plates. The heated plate expands and contracts and this creates cracks in the hard sulfation.Isn't it destroying the plates because usually the welders are 20-28 volts ???
Well, I guess you learned something new?I have always seen saying never to charge a battery with more voltage than recommended
Should i filter the fluid after desulfating ?It is actually 5 minutes welder on, rest for 10 minutes, 5 minutes on and repeat for 5 times.
Soft sulfation can be chemically reversed, hard sulfation can not. It is permanent and comprised of lead and sulfuric acid. Hard sulfation will stick on the plates preventing any new lead/acid chemical reaction leading to reduced battery capacity and cranking amps.
Using a welder works, it won't save all batteries and some will provide enough cranking amps but have reduced load capacity. I use those in something like a lawnmower that doesn't require many Ah's.
It requires paying attention to details such as battery temp, following proper safety procedures and understanding what is occurring inside the battery.
I don't, I let any hard sulfation settle to the bottom. If you drain a battery by turning it upside down, any large particles of hard sulfation from the bottom could get in between the plates and create a short.Should i filter the fluid after desulfating ?
I use about 90A.I don't think that it gave more capacity to the battery. I gained maybe 5Ah.
I coocked 5 times the battery with about 45amps current. Every holes was bubbling inside.
I can't put more than 45 Amps or i will loose all the fluid... It was bubbling a lot. And I could barely touch the battery because it was so hotI use about 90A.
A heavily sulfated battery will have reduced capacity even after knocking the sulfation off the plates. It is due to the reduction of lead and acid that is locked into the hard sulfated material.
I've done EQ charge on 6 volt batteries from a golf cart for weeks, charging, then discharging. Charging and discharging will cause plates to shed sulfation as the plates expand and contract. Each time the capacity increased until 4 recovered to over 90% capacity but the remaining 2 would only go slightly above 80%. I probably did 10 complete cycles. Capacity was pretty pathetic the first few times. It was about double the original capacity when I finished. The 2 duds were retired.
What voltage?I can't put more than 45 Amps or i will loose all the fluid... It was bubbling a lot. And I could barely touch the battery because it was so hot
20vWhat voltage?
I watch temp, nothing over 110°F.
Cycle it a few times, you might have material in between plates.
