Make that all the "older" sunny boys.
the -40/-41 do not. Have SpeedWire (Ethernet) instead.
Some have Bluetooth, but due to supply chain issues presently may be delivered with or without, you won't know which, and can't retrofit.
The Sunny Boys shown compatible with "Backup" operation used to be the ones which could accept RS-485 daughter card. Now, those with Rule-21 (UL-1741-SA frequency-watts) are also shown.
Strangely, TL-US-22 is shown as compatible with backup but not off-grid? My guess is they do not have an off-grid setting, but with RS-485 they will switch to off-grid parameters when told to do so by Sunny Island.
The TL-US-22 and the TriPower take a different model RS-485 module. For TriPower, I see nothing other than serial number through RS-485, maybe my monitoring hardware needs firmware update. Through SpeedWire, I am able to configure them.
TLUS-10 and -12 were previously listed as supporting both backup and off-grid, no longer shown for backup due to firmware bug (you can thank me for that change in the compatibility list.)
Although a SpeedWire module is available for Sunny Island, that does not appear supported for controlling newer Sunny Boys, just for reporting to monitoring hardware. (SpeedWire to RS-485 interfaces are another monitoring option.)
The Sunny TriPower TL-US-10 are listed as not being compatible with backup. The do implement frequency-watts, and I was able to adjust frequency range for backup. Firmware update is supposed to support Rule-21. Either way, if wattage exceeded Sunny Island's relay current, that would be a problem while stuck at 60 Hz on-grid. (I'm thinking about SpeedWire for limited export. For utility meter, brief over-current but target average should be OK. For SI relay, I don't know how fast it needs to be, could hit 2x rated current.)
