OffGridForGood
Catch, make or grow everything you can.
LOL!, my own CST has given a green-light the next expansion: a third inverter this summer, followed by more PV and two more DIY batteries LOL.Oh it's gonna happen!
It helps when the boss is onboardLOL!, my own CST has given a green-light the next expansion: a third inverter this summer, followed by more PV and two more DIY batteries LOL.
Yes ok I am thinking the system will be in the 200-300 volt range@joesmith123 -
If you buy the PV panels and install them on the roof on the S-5 supports, you will need to connect up the series and parallel connections as you go, since it will be near impossible to access under those panels once installed - without removing them again.
Be sure to plan out the max VOC and allowable string amperages to suit your sustem so those PV panels can be correctly connected as you install them.
I know @joesmith123 seems determined to buy these panels but just looking at the info we have and the total cost being something like $2600 I did a little math and if you factor in something generous such as expectation of getting 80% production out of all the panels that's around 8800w. You can get that much out of new panels with way less panels, and as you just pointed out, way less S-5 mounts for less than twice that - maybe $4500 or so including shipping if you shop around. That makes way more sense to me, but it's not my build.
You also made a great point on installing the panels before you know the exact configuration. Trying to change the wiring scheme on panels installed on the roof can be a nightmare. I'm going to have to change mine when I upgrade inverters but I purposely left a gap between every other row so I can get to the wiring of every panel without having to remove any of the others. I also left a 4' gap at the bottom for working space because with 17' eaves I don't want to fall off trying to work on them. So I sacrificed available space for more panels in exchange for easy access down the road, and I'm glad I did so. Even with that it's a little bit of PITA to redo the wiring.
Edit: With the stated loads you could cover those loads with a LOT less panels so there's that to think about as well. Depending on insulation, I don't think the shading the roof thing is going to have as much of an impact as is being anticipated.
yeah - the Chief Solar Tester, CST!
Now we look at the loads:
A fridge - even our large side by side, is only a 1.4kWh/day load.
The window A/C will be much larger, depends on cycles and how big this A/C is, do we say 400-500W continuous on average = 8-10kWh/day?
Add some other normal items maybe 20-24kWh per day
64 PV panels x 180W each x 80% x 4hrs =46kWh/day?
As ETC said, a smaller number of new(er) PV panels could supply 20kWh/day, with fewer roof brackets, less wire, lower cost.
Yes thank youSounds like you are in the correct voltage range of your inverter.
I'm not even to finding anything for 25 cents a watt, including used
Blemished Canadian 250W Solar Panel | SanTan Solar
These Canadian 250W Solar Panels have water intrusion, which has caused discoloration on the vinyl and busbars. Please see pictures for more details.www.santansolar.com
$45, 250W (STC rating, may be less aged), that's $0.18/W
Not necessarily recommending this one, just an example.
There are probably some new panels in the $0.50 range. But I consider used at $0.25 a better deal, unless some are severely degraded.
You pay for shipping. I have pallet(s) delivered to freight terminal, get them with my pickup.
Shipping anything nowadays is going to cut into the value of it
Half of my shipments nowadays either get stolen by the neighbors, or the mailman cant find the address etc
They quote shipping.
My last order, one pallet to a freight terminal in San Jose, cost $359 shipping.
Costs are way up compared to 3.5 years ago.
The cost for multiple pallets may not be a multiple of that figure.
I've received 25 or so panels per pallet.
Yup.
Several reasons I prefer to pick up at freight terminal.
Use Craigslist, and eBay sorted by distance, to find things close.
Call local installers, ask if they have leftover new panels or taken down old ones from jobs. They would otherwise dump to liquidators like Santan.
I was shopping for ESD flooring, found it 5 miles away in a Craigslist posting.
(That after eBay merchant ignored multiple requests to re-quote shipping by something other than Priority Mail.)
The main risks on those Sharp panels are:
Some do not produce at all - testing could remove those from the mix.
They work but are severly degraded, resulting in very low production = higher cost per Watt
They work okay but for a short time, resulting is low production, time spent trying to find which panel in a six panel string is the problem one.
Imagine 64 panels up on a roof, a few have dropped out, - now try to find which ones, and pull them out from the others without removing many others just to gain access - ETC has a good suggestion on this, leave access lane between every double row. If you have a sting of 6 PV and one fails, you remove that one - make up a short MC-3 cable extension to get the other 5 producing, okay, that string can't be combined with a string of 6, you need them to match if they come together in a combiner box.
A failed panel once removed will need a similar size and capacity panel to go in it's place. (physical dimensions and output)
You may be better off to get spares while you are getting these Sharp panels, at least you would have a pool of spares to work with of same sizes and output, I would suggest they should drop the price for you based on taking 64 plus spares, maybe allow you to test later and return for credit any that fail testing, to save the time of doing all the testing on day of pick up.
There are some videos and threads about older cracked PV panels leading to fires (not saying the sharp panels are cracked), I don't know enough about it to comment here, other than to say it would be a concern to me if the roof with the PV will also have people living under it.
As I said earlier, you know your situation better than we do. Do what you need to do, we each have offered our input, but this is your money, your life your decision. I truely hope the panels are decent and you get good use out of them, and solve your urgent issue concerning generators.
On cash private deals, I have found a nice thick stack of $100 bills is a great incentived for the seller to negotiate.
My favorite is put $2,000 in an envelope (and the rest in your pocket) see it they will accept 2,000 for 74 panels...when people see the cash, especially if they feel you just might drive away, they often strike a deal.
Is there a reason you have not mounted your inverter yet?Am I going in the right direction?
I do have an inverter mountedIs there a reason you have not mounted your inverter yet?
