I bought similar ones off of Alibaba. 60 @ $16.60 each. I did CIF, but hindsight DDP would not have cost much more, and it would have been less of a headache.I wish I could purchase those powerfield buckets off Amazon.
They're Heavier.What about the buckets from Powerfield?View attachment 189973View attachment 189972?
I haven’t seen any of those buckets more than 25°They're Heavier.
And block some of the wind flowing under.
Which are both helpful.
I need a 53 degree option. i don't think ballasted will be an option.
The other day was 45+ mph winds sustained for over 4 hours. Gusts over 50 mph.They're Heavier.
If I installed a ballast mount no matter the angle, I would most likely have seen it flying by my windows at some point.
I have no idea how some of you get away with a ballast mount. I doubt my insurance would even consider insuring one here. I'll stick with my cheap mounts on the expansion. https://diysolarforum.com/threads/sinclair-or-mt-solar.76590/ Ordered 3 poles from a local welding shop I buy material from at around $500 each.
I have those buckets 6 rows of seven panels. Eight buckets per row. Each bucket has 85 pounds of ballast. I’m up on a hill that is very windy, I have been getting more than 50 mph winds. They don’t budge.The other day was 45+ mph winds sustained for over 4 hours. Gusts over 50 mph.
If I installed a ballast mount no matter the angle, I would most likely have seen it flying by my windows at some point.![]()
Turn them the other way and fill them with concrete. lolI haven’t seen any of those buckets more than 25°
But I think you could go up as high as 60°-ish if you just added more buckets and ballast. Besides the buckets on either end of the panels, add buckets in the middle too.
They are made of black HDPE.And in the AZ desert or FL with the sun how long does the plastic last.
Depending on the percentages of UV absorbent additives added, HDPE will be longer resistant to UV exposure. Black HDPE with added carbon black additive can last longer than 50 years under direct UV exposure.
In AZ, about a week if it gets sun. However as long as it doesn't get sun or if you put a heavy coat of paint on it, much longer.And in the AZ desert or FL with the sun how long does the plastic last.
Bwahahahahahahahahah. Yea it won't. Sun here is the most brutal thing I've ever dealt with on plastics. Maybe 20-25, maybe. The 'dashmat' for cars was originally created for phoenix.Depending on the percentages of UV absorbent additives added, HDPE will be longer resistant to UV exposure. Black HDPE with added carbon black additive can last longer than 50 years under direct UV exposure.
Yes, not in DIRECT sunlight for 50 years as stated. Paint helps a lot.It does look like glass reinforced HDPE. It probably will last a really long time. They are also shaded by the panels.
If you say so........The powerfields are 550 lb when filled to the brim with sand or gravel with a wind load rating of 120mph.
Glad to hear that. I have some Powerfields on order ?I have those buckets 6 rows of seven panels. Eight buckets per row. Each bucket has 85 pounds of ballast. I’m up on a hill that is very windy, I have been getting more than more than 50 mph winds. They don’t budge.
